Hi
Looking to get the APPS (MySolar) that are available in the PI verison to install inside the docker contianer, I did try to modify the dockerfile but guessing I didnt do correctly, anybody able to help with this?
Reason for a Docker is that this is then a wired connection rather than the slow wifi from the PI (location bound) once this is working I will add another feed from a second solar array on the garage which is currently unmonitored.
John
I was misisng the graph in my guess at the path, having followed the steps to update I am now faced with
Database error, you may need to run database update…
Guess I need to clear down the containers, unless there is a quick way to remove the database and rebuild it.
There is a big difference in the modules installed in the docker version to the Pi, is there a reason for this?
On docker I have
Modules Administration | App v1.2.0 | Dashboard v1.3.1 | EventProcesses | Feed | Graph v1.2.1 | Input | CoreProcess | Schedule | Time | User | Visualisation
Reason for asking is was looking to make use of the Sync module to send dashboard/feeds etc, which on the emonpi this seems ot connect and upload but the items are not seen on the docker install.
