The “bad packet count” means that individual cell received a packet of data which was corrupt - so the corruption occurred between the previous module and that one.
Usually, running at a slower clock speed will help, as it allows the ATTINY to align to the data stream more accurately.
Out of Sequence is basically the same as a CRC error except that instead of a corrupt packet you have no packet. Possibly a missed wake-up interrupt or something like that.
I’ve been replacing cpus to fix the crc issues, oos must also be hardware related since the creator of the boards runs 9k6 comms speed and has 0 errors. Could optoisolators be a culprit? I can’t imagine that I got 114 bad CPU’s. I’m starting to run out of ideas beyond ordering new boards and cpus and spending another $400.
Does anybody have an extra current monitor board they would be willing to part with? I can’t see making an order on Jlcpcb just for 1 board. Preferably in the US.
Hello everyone,
I am new here, have already checked the majority of the videos (very impressive, thank you!) and have following question: is the balancing done purely by resistive energy burning and is it centrally controlled?
Is this balancing principle more beneficial (the preis is lower e.g. compared with inductive solutions like DC2100 which is for me “unpayable”)?
If somebody could share his experience regarding the effectiveness of the circuit that would be great.
But its an easy solution. Active balancing needs complicate cableling.
This system is very flexible and can handle a huge amount of cells.
It has a webserver and can be installed in your home WIFI to monitor and configure.
It has diffrend relais to switch functions.
It has RS485 and also a CAN BUS solution.
And its easy and cheap to manufacture and configure.
I have a strange issue with my newly built BMS
4 prismatic 304Ahr cells in series
When the controller sends a packet it seems to do multiple ‘round-trips’
the controller flashes, then 1,2,3,4,1,2,3,4,1,2,3,4 etc no extras controller flashes
The controller also reports each received packet via mqtt i.e. they arrive in bursts
BUT the rx & tx packet counters increment together so it would seem the controller is sending multiple packets
Communication speed is std, 6000ms interval latest controller & V4.4 cell boards
hi stuart did the 2D/3D mode get removed from the esp32 version?, i cant no longer see it on the september build on the main screen, used to be at the bottom of the screen
The controller flashes “green” when the “enqueue_task” is called. That function can request multiple packets of data to be sent, and this is all normal behaviour.
Nearly complete 28KWH Nissan Leaf Cells. Anybody have any good guess what it can discharge max? I’m thinking around 20kw. I was reading that the leaf packs were known to discharge around 80kw. I was running these packs at 10KW daily last year before the new BMS.
