yes . JCBPCB has sender the boards today I thin at the end of the week are in Malaga. An 10 New controller arrived after tomorrow ( now in France) for the spanish team.
Thank you so much for sharing your knowledge and experience, I have integrated diy bms into home assistant, but the parameter cell range is not published. It’s very strange.
A lot of the parameters can be calculated outside of diyBMS, thats why I didn’t publish everything - to work out the range you just need to find the max and min of the cell voltages
You don’t need to download anything - please follow the instructions on the GITHUB page on how to flash the firmware to the ESP32
I had the bms slaves more than a year before i found my leaf cells so i was not able to get the specific leaf bms boards, in case you are in the same boat i made these brackets:
a charitable soul that is encouraged to pass this design to kidcad to be able to use v4.40 in Lifepo4?
I have the file of the plate in inventor, but I suppose it can be changed to another format.
Thank you so much for your answer and congratulations for your excellent job!
Why is the esp8266 controller bom file empty?
Thank you!
Very good question!
Looks like an oversight on my part, I’ve uploaded a fresh copy of the BOM/CPL and GERBER files.
Thanks.
Ok, are you ok to do a pull request?
Just making sure you are aware of the new controller design? This is the old/legacy one
Hello Stuart, I set up the lifepo4 battery, but the diybms show errors, I twisted the wires but the errors continue, could you help me, please?
and also a screenshot of the “modules” page from a computer web browser - I need to see the “Bad packet count” column.
