DIYBMS Case? Holder? Din rail mount?
Does anyone have a 3d model for a case, or holder, or din rail mount for the diybms? I saw briefly a base in one of Stuart’s videos but could not seem to find the model anywhere. I would like to have a couple 3d printed.
To hold the controller board.
thx
-Dennis
lijun Transparenter Kunststoff PLC Industrieschaltkasten Panel PLC Gehäuse DIY PCB Shell : Amazon.de: Sonstiges
514B0YwFijL.AC_SX569
Hi.
To DIN rail mount my controller I’ve use the matching mounts originally designed by Voron team for Voron 2.4 3d printer - Fysetc controller (same 80mm hole pattern).
You will need:
1x controller bracket
2x PCB DIN clip
DiyBmsControllerBase.zip (40.8 KB)
Here is a DIN base for Diy BMS that I made. Needs 4x m3 x 8mm capheads, 4x m3 x 10mm capheads and 8x m3 nuts.
The Din clip needs to be printed normal for the LHS and Mirrored for the RHS.
Regards
Ste
This is really fantasic!
