Hi All,
I have installed an EmonESP to a EmonTX v3, i would like to disable the 433Mhz from broadcasting is it just a case of changing a line in the firmware to “boolean RF_STATUS = 0”
//-----------------------RFM12B / RFM69CW SETTINGS----------------------------------------------------------------------------------------------------
byte RF_freq=RF12_433MHZ; // Frequency of RF69CW module can be RF12_433MHZ, RF12_868MHZ or RF12_915MHZ. You should use the one matching the module you have.
byte nodeID = 8; // emonTx RFM12B node ID
int networkGroup = 210;
boolean RF_STATUS = 1; // Enable RF
