Robert - here’s where I’m currently at …
Using the .ino file you sent but with SERIALOUT substituted in line 165
Just one CT connected plus AC adapter plus pulse sensor
The RFM2Pi interfacer deleted from the emonhub config
This interfacer used instead …
[[SerialTx3e]]
Type = EmonHubTx3eInterfacer
[[[init_settings]]]
com_port= /dev/ttyAMA0
com_baud = 115200
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
With Node 11 following yr suggestion (except datacodes rather than datacode) …
[[11]]
nodename = 3phase
[[[rx]]]
names = powerL1, powerL2, powerL3, power4, Vrms, pulse
datacodes = h,h,h,h,h,L
scales = 1,1,1,1,0.01,1
units =W,W,W,W,V,p
The result in the log is …
2017-04-16 22:02:15,837 INFO MainThread EmonHub emonHub ‘emon-pi’ variant v1.2
2017-04-16 22:02:15,838 INFO MainThread Opening hub…
2017-04-16 22:02:15,838 INFO MainThread Logging level set to DEBUG
2017-04-16 22:02:15,839 INFO MainThread Creating EmonHubTx3eInterfacer ‘SerialTx3e’
2017-04-16 22:02:15,842 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 115200 bits/s
2017-04-16 22:02:15,843 DEBUG MainThread Setting SerialTx3e pubchannels: [‘ToEmonCMS’]
2017-04-16 22:02:15,844 DEBUG MainThread Interfacer: Subscribed to channel’ : ch2
2017-04-16 22:02:15,846 INFO MainThread Creating EmonHubMqttInterfacer ‘MQTT’
2017-04-16 22:02:15,847 INFO MainThread MQTT Init mqtt_host=127.0.0.1 mqtt_port=1883 mqtt_user=emonpi
2017-04-16 22:02:15,850 DEBUG MainThread MQTT Subscribed to channel’ : ToEmonCMS
2017-04-16 22:02:15,851 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer ‘emoncmsorg’
2017-04-16 22:02:15,853 DEBUG MainThread emoncmsorg Subscribed to channel’ : ToEmonCMS
2017-04-16 22:02:15,952 INFO MQTT Connecting to MQTT Server
2017-04-16 22:02:15,955 INFO MQTT connection status: Connection successful
2017-04-16 22:02:15,957 DEBUG MQTT CONACK => Return code: 0
2017-04-16 22:02:16,058 INFO MQTT on_subscribe
2017-04-16 22:02:22,497 WARNING MainThread SerialTx3e thread is dead
2017-04-16 22:02:22,699 WARNING MainThread SerialTx3e thread is dead
However, minicom reports …
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Jan 12 2014, 05:42:53.
Port /dev/ttyAMA0, 17:41:08
Press CTRL-A Z for help on special keys
11 589 0 0 0 25744
11 619 0 0 0 25800
11 582 0 0 0 25893
Current & voltage sensors are reporting but the pulse sensor is not
Now if I shutdown and just substitute a temp sensor for the pulse sensor and change Node 11 accordingly to …
[[11]]
nodename = 3phase
[[[rx]]]
names = powerL1, powerL2, powerL3, power4, Vrms, temp1
datacodes = h,h,h,h,h,h
scales = 1,1,1,1,0.01,0.1
units =W,W,W,W,V,C
SerialTx3e thread is still dead however Minicom now reports …
OPTIONS: I18n
Port /dev/ttyAMA0, 22:18:55
11 602 0 0 0 25891 217
11 615 0 0 0 25886 217
11 599 0 0 0 25923 217
11 607 0 0 0 25921 217
Current, voltage & temp sensors are all reporting
In summary …
The pulse sensor is not reporting.
And the format of reports in general seems unacceptable to emonhub.
What is the significance of the leading 11 in the reports? Could the body be buried there?
Thx for yr support
