In migrating to my new system, I’m having problems importing a tar.gz file from the old system (Emoncms Core v11.10.3 | App v3.1.6 | EmonHub Config v2.1.6) into the new. I did this once but can’t seem to get it to work again with a later update. The usb isn’t recognized or at least it sees it as an unmounted drive at /dev/sdb. I have a mounted usb drive at /dev/sda (/mnt/usb0) which I use for backups and this seems to be working.
=== USB Emoncms import start ===
2026-05-28-10:15:50
Backup module version:
"version" : "2.3.7",
EUID: 1000
Reading /opt/emoncms/modules/backup/config.cfg....
Location of data databases: /var/opt/emoncms
Location of emonhub.conf: /etc/emonhub
Location of Emoncms: /var/www/emoncms
Scanning for USB card reader:
- Mounted disk: /dev/disk/by-id/usb-Kingston_DataTraveler_3.0_94DE80724791E2C0793E1C41-0:0 at /dev/sda
- Unmounted disk: /dev/disk/by-id/usb-Mass_Storage_Device_121220160204-0:0 at /dev/sdb
- Error: Unmounted disk has incorrect number of partitions
- No card reader found on sdc
- No card reader found on sdd
- No card reader found on sde
USB drive not found
# Emoncms Export and Import scripts config file
## DEFAULT CONFIG ##
# These settings are used for both the export and import scripts.
# To export from one location and import into another
# Used by both PHP and Bash and comments are not ignored
# Change all capitalised placeholders to relevant locations
# user
user="pi"
backup_script_location="/opt/emoncms/modules/backup"
# Directory location of Emoncms
emoncms_location="/var/www/emoncms"
# Destination location of exported backup .tar.gz - Must be writable
#backup_location="/var/opt/emoncms/backup"
backup_location="/mnt/usb0"
# location of phpfina phpfiwa and phptimeseries databases
database_path="/var/opt/emoncms"
# Location of emonhub.conf - leave blank if backup not required
emonhub_config_path="/etc/emonhub"
# Location of specimen emonhub config
emonhub_specimen_config="/opt/openenergymonitor/emonhub/conf"
# Location of compressed backup data to import .tar.gz
backup_source_path="/var/opt/emoncms/backup/uploads"
pi@emonpi:~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 961M 0 loop
sda 8:0 1 57.8G 0 disk
└─sda1 8:1 1 57.7G 0 part /mnt/usb0
sdb 8:16 1 29.7G 0 disk
└─sdb1 8:17 1 29.7G 0 part
mmcblk0 179:0 0 59.5G 0 disk
├─mmcblk0p1 179:1 0 512M 0 part /boot/firmware
├─mmcblk0p2 179:2 0 6.5G 0 part /var/log.bak
└─mmcblk0p3 179:3 0 52.4G 0 part /var/opt/emoncms
zram0 254:0 0 2G 0 disk [SWAP]
Not sure what is going on here but I must be doing something wrong. The system seems to be working ok otherwise, anyway as far as I can tell so far.
Thanks. I can send more details if needed.
Cheers,
Bob
