Hi I need this group support on how to get a better aligned amperage between the setpoint and current . In my case in particular I’ve about 3 amps difference so far I’ve tried to update using the RAPI command $SA 225 0 alway get the same result “undefined” then I tried via HTTP (http://192.168.68.222/r?json=1&rapi=$SC+215+0) was also unsuccessful (error “RAPI_RESPONSE_BLOCKED”) and finally via MQTT and same outcome.
After further research seams that latest version of OpenEVSE Wifi v5.1.0_modified does not support changes to this configurations.
I’m already providing via mqtt the current voltage but that doesn’t help.
In this case what will be the best solution to fix this problem?
