Just did a full upgrade of my emonbase and the SDM120 modbus appears to have broken as a result.
Any ideas? I’ve rebooted the pi but still the same. Had a look at the config and it doesn’t appear to have changed but I expect the underlying code probably has.
2022-10-29 00:55:00,039 ERROR SDM120 Could not read all registers
2022-10-29 00:55:00,039 INFO SDM120 Connecting to Modbus device=/dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0 baud=9600 parity=none datatype=float
[EDIT] I’ve also switched off the power feed to the SDM120 in the consumer unit and restarted it but no joy.
[EDIT2] The config is as below and I don’t think it changed during the upgrade. Bottom line is the feed ground to a halt after the upgrade.
[[SDM120]]
[[[init_settings]]]
device = /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
baud = 9600
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
read_interval = 10
nodename = sdm120
# prefix = sdm_
registers = 0,6,12,18,30,70,72,74,76
names = V,I,P,VA,PF,FR,EI,EE,RI
precision = 2,3,1,1,3,3,3,3,3
[Edited for legibility - Moderator (RW)]
For future reference, when posting code or output, please put 3 ‘backticks’ (normally found at the top left of the keyboard) on a line of their own before the code, and 3 more backticks also on a line of their own after the code:
code
If it is something like php you can add a language identifier after the first 3 backticks: ```php
or even ```text
if you don’t want any language markup applied.
