after a reboot of emonhub I am no more receiving data from sensors.
I tried soft and hard reboot but no way.
I found following error in emonhub logs:
2018-01-09 20:27:57,551 DEBUG MainThread SIGINT received.
2018-01-09 20:27:57,553 INFO MainThread Exiting hub…
2018-01-09 20:27:57,608 INFO MainThread Exit completed
2018-01-09 20:28:00,858 INFO MainThread EmonHub emonHub emon-pi variant v2.0.0
2018-01-09 20:28:00,860 INFO MainThread Opening hub…
2018-01-09 20:28:00,863 INFO MainThread Logging level set to DEBUG
2018-01-09 20:28:00,866 INFO MainThread Creating EmonHubJeeInterfacer ‘RFM2Pi’
2018-01-09 20:28:00,875 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2018-01-09 20:28:02,881 WARNING MainThread Device communication error - check settings
2018-01-09 20:28:02,884 INFO MainThread Setting RFM2Pi frequency: 868 (8b)
2018-01-09 20:28:03,888 INFO MainThread Setting RFM2Pi group: 210 (210g)
2018-01-09 20:28:04,892 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2018-01-09 20:28:05,896 INFO MainThread Setting RFM2Pi baseid: 15 (15i)
2018-01-09 20:28:06,900 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2018-01-09 20:28:07,904 DEBUG MainThread Setting RFM2Pi subchannels: [‘ToRFM12’]
2018-01-09 20:28:07,907 DEBUG MainThread Setting RFM2Pi pubchannels: [‘ToEmonCMS’]
2018-01-09 20:28:07,911 INFO MainThread Creating EmonHubMqttInterfacer ‘MQTT’
2018-01-09 20:28:07,915 INFO MainThread MQTT Init mqtt_host=127.0.0.1 mqtt_port=1883 mqtt_user=emonpi
2018-01-09 20:28:07,925 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer ‘emoncmsorg’
2018-01-09 20:28:08,031 INFO MQTT Connecting to MQTT Server
2018-01-09 20:28:08,043 INFO MQTT connection status: Connection successful
2018-01-09 20:28:08,047 DEBUG MQTT CONACK => Return code: 0
2018-01-09 20:28:08,152 INFO MQTT on_subscribe
2018-01-09 20:28:22,941 INFO emoncmsorg sending: https://emoncms.org/myip/set.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y
2018-01-09 20:28:37,980 INFO emoncmsorg sending: https://emoncms.org/myip/set.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y
Any guess ?
Probably I tried an upgrade (unaware of what I was doing …) see attachment with inconsistent versions.
