I’m sure I have mentioned this before.
On a fresh install, demandshaper takes a massive amount of CPU
On install
Stop the demandshaper service
On install
Thanks, I can’t immediately replicate this, demandshaper on my pi running ok with low load and testing on my computer locally with no devices also shows low load. Is this emonSD-17Oct19? I will make a note to check on a new pi without any changes? Did you see this before/after registering the first user? does the user have any inputs/devices?
It was an Ubuntu VM on my new Proxmox setup (that is absolutely brilliant). Not had a chance to investigate. I’ll spin up another container and install again.
