Ryan_S
(Ryan S.)
28 May 2020 08:22
#1
Seems like after the last update the DemandShaper no longer starts. At least, now when I go to either of my 2 I see this.
I’ve check both OpenEVSE units and MQTT shows connected.
On server information Demand Shaper shows Auto Restart.
Server Information
Server Information
Services
emonhub :- Active Running
emoncms_mqtt :- Active Running
feedwriter :- Active Running - sleep 300s 1950 feed points pending write
service-runner :- Active Running
emonPiLCD :- Inactive Dead
redis-server :- Active Running
mosquitto :- Active Running
demandshaper :- Activating Auto-restart
Emoncms
Version :- low-write 10.2.3
Modules :- Administration | App v2.1.6 | Backup v2.2.3 | EmonHub Config v2.0.5 | Dashboard v2.0.7 | DemandShaper v1.2.5 | Device v2.0.5 | EventProcesses | Feed | Graph v2.0.9 | Input | Postprocess v2.1.4 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.2
Git :-
Server
OS :- Linux 4.19.75-v7+
Host :- emonpi | emonpi | (192.168.1.24)
Date :- 2020-05-28 09:22:08 BST
Uptime :- 09:22:08 up 5 min, 0 users, load average: 0.09, 0.43, 0.26
Memory
RAM :- Used: 16.62%
Total :- 975.62 MB
Used :- 162.15 MB
Free :- 813.47 MB
Swap :- Used: 0.00%
Total :- 100 MB
Used :- 0 B
Free :- 100 MB
Write Load Period
Disk
/ :- Used: 49.33%
Total :- 3.92 GB
Used :- 1.94 GB
Free :- 1.79 GB
Write Load :- n/a
/boot :- Used: 20.55%
Total :- 252.05 MB
Used :- 51.79 MB
Free :- 200.26 MB
Write Load :- n/a
/var/opt/emoncms :- Used: 3.41%
Total :- 9.98 GB
Used :- 348.82 MB
Free :- 9.13 GB
Write Load :- n/a
/var/log :- Used: 99.61%
Total :- 50 MB
Used :- 49.8 MB
Free :- 200 KB
Write Load :- n/a
HTTP
Server :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version :- 5.5.5-10.3.17-MariaDB-0+deb10u1
Host :- localhost:6379 (127.0.0.1)
Date :- 2020-05-28 09:22:07 (UTC 01:00)
Stats :- Uptime: 300 Threads: 15 Questions: 943 Slow queries: 0 Opens: 54 Flush tables: 1 Open tables: 48 Queries per second avg: 3.143
Redis
Version :-
Redis Server :- 5.0.3
PHP Redis :- 5.0.2
Size :- 284 keys (845.62K)
Uptime :- 0 days
MQTT Server
Version :- Mosquitto 1.5.7
Host :- localhost:1883 (127.0.0.1)
PHP
Version :- 7.3.9-1~deb10u1 (Zend Version 3.3.9)
Modules :- apache2handlercalendar Core ctype curl date dom v20031129exif fileinfo filter ftp gd gettext hash iconv json v1.7.0libxml mbstring mosquitto v0.4.0mysqli mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $openssl pcre PDO pdo_mysql Phar posix readline redis v5.0.2Reflection session shmop SimpleXML sockets sodium SPL standard sysvmsg sysvsem sysvshm tokenizer wddx xml xmlreader xmlwriter xsl Zend OPcache zlib
Pi
Model :- Raspberry Pi 3 Model B+ Rev 1.3 - 1GB (Sony UK)
Serial num. :- 3BD68E61
CPU Temperature :- 52.62°C
GPU Temperature :- 52.6°C
emonpiRelease :- emonSD-17Oct19
File-system :- read-only
Client Information
Client Information
HTTP
Browser :- Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.61 Safari/537.36
Language :- en-US,en;q=0.9
Window
Screen
borpin
(Brian Orpin)
28 May 2020 09:07
#2
try
systemctl status demandshaper.service
what does it tell you?
Ryan_S
(Ryan S.)
28 May 2020 11:31
#3
This repeating on the output.
Of note seems to be this.
Process: 3114 ExecStart=/usr/bin/php /opt/emoncms/modules/demandshaper/demandshaper_run.php (code=exited, status=255/EXCEPTION)
Main PID: 3114 (code=exited, status=255/EXCEPTION)
borpin
(Brian Orpin)
28 May 2020 11:42
#4
Instead of a screenshot, please select the text and post between 3 backticks such that
text
What I would expect is
[email protected] :~ $ systemctl status demandshaper.service
● demandshaper.service - Emoncms Demandshaper service
Loaded: loaded (/lib/systemd/system/demandshaper.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2020-05-23 18:35:23 BST; 4 days ago
Docs: https://github.com/emoncms/demandshaper/blob/master/readme.md
Main PID: 628 (php)
Tasks: 1 (limit: 2319)
Memory: 5.9M
CGroup: /system.slice/demandshaper.service
└─628 /usr/bin/php /opt/emoncms/modules/demandshaper/demandshaper_run.php
May 23 18:35:23 emonpi systemd[1]: Started Emoncms Demandshaper service.
But something at the bottom suggesting why it could not start.
Try
from the command line.
You could also try restarting the service
sudo systemctl restart demandshaper.service
and then checking the logs
sudo journalctl -f -u demandshaper
Ryan_S
(Ryan S.)
28 May 2020 14:00
#5
Not a problem.
Active: activating (auto-restart) (Result: exit-code) since Thu 2020-05-28 14:57:09 BST; 8s ago
Process: 3188 ExecStart=/usr/bin/php /opt/emoncms/modules/demandshaper/demandshaper_run.php (code=exited, status=255/EXCEPTION)
Main PID: 3188 (code=exited, status=255/EXCEPTION)
Out for
[email protected] :~ $ /usr/bin/php /opt/emoncms/modules/demandshaper/demandshaper_run.php
PHP Fatal error: Uncaught ErrorException: Undefined variable: date in /opt/emoncms/modules/demandshaper/scheduler.php:213
Stack trace:
#0 /opt/emoncms/modules/demandshaper/scheduler.php(213): exceptions_error_handler(8, 'Undefined varia...', '/opt/emoncms/mo...', 213, Array)
#1 /opt/emoncms/modules/demandshaper/demandshaper_run.php(398): get_forecast(Object(Redis), 'carbonintensity', 'America/New_Yor...')
#2 {main}
thrown in /opt/emoncms/modules/demandshaper/scheduler.php on line 213
Stack trace:
#2 {main}
Finally trying to restart it.
[email protected] :~ $ sudo systemctl restart demandshaper.service
[email protected] :~ $ sudo journalctl -f -u demandshaper
-- Logs begin at Thu 2020-05-28 13:52:22 BST. --
May 28 14:59:50 emonpi demandshaper[3261]: #2 {main}
May 28 14:59:50 emonpi demandshaper[3261]: thrown in /opt/emoncms/modules/demandshaper/scheduler.php on line 213
May 28 14:59:50 emonpi demandshaper[3261]: Fatal error: Uncaught ErrorException: Undefined variable: date in /opt/emoncms/modules/demandshaper/scheduler.php:213
May 28 14:59:50 emonpi demandshaper[3261]: Stack trace:
May 28 14:59:50 emonpi demandshaper[3261]: #0 /opt/emoncms/modules/demandshaper/scheduler.php(213): exceptions_error_handler(8, 'Undefined varia...', '/opt/emoncms/mo...', 213, Array)
May 28 14:59:50 emonpi demandshaper[3261]: #1 /opt/emoncms/modules/demandshaper/demandshaper_run.php(398): get_forecast(Object(Redis), 'carbonintensity', 'America/New_Yor...')
May 28 14:59:50 emonpi systemd[1]: demandshaper.service: Main process exited, code=exited, status=255/EXCEPTION
May 28 14:59:50 emonpi systemd[1]: demandshaper.service: Failed with result 'exit-code'.
borpin
(Brian Orpin)
28 May 2020 14:03
#6
Ok thanks. @Gwil @TrystanLea @glyn.hudson will need to have a look. They should know where to look now.
Ryan_S
(Ryan S.)
28 May 2020 14:34
#7
No problem. lol. Only reason I even noticed this was I went in to see about changing the charge current for my OpenEVSE charger for summer charging.
Hello @Ryan_S I think this may have been caused by a change to the settings structure in the more recent version. It’s possible to clear this by deleting the device and recreating it - but that will delete the associated inputs and input processing as well. If that’s easy to recreate for you then that’s probably the quicker route to getting this back up and running. Otherwise I can take a look to see if I can fix the issue in the code.
Could you check if there are any javascript errors in the browser console?
