Dashboard View with Local Emonbase Misalignment at Dashboard, Buster 10.1.11. when I am not logged in
Installation on Buster 10.1.11 with image and data migration from 9.9.6 ran without problems,
thank you for your tireless and excellent work.
However I have in the local Dashboard a misalignment which is unfortunately very disturbing.
Where can I adjust it?
This problem only appears on my dashboard when I am not logged in.
http://emonpibu/emoncms/user.
I am logged in or in the Dashboard Layout Editor, everything is ok.
http://emonpibu/dashboard/view/001
Can the menu line also be reduced? Where do I have to change this?
The background is that my dashboard was completely visible on the browser without scrolling,
this is no longer the case.
Server Information
Server Information
Services
  • emonhub :- Active Running
  • emoncms_mqtt :- Active Running
  • feedwriter :- Active Running - sleep 300s 126 feed points pending write
  • service-runner :- Active Running
  • emonPiLCD :- Inactive Dead
  • redis-server :- Active Running
  • mosquitto :- Active Running
  • demandshaper :- Active Running
Emoncms
Server
  • OS :- Linux 4.19.83-v7+
  • Host :- emonpibu | emonpibu | (10.255.255.26)
  • Date :- 2019-11-17 10:11:24 CET
  • Uptime :- 10:11:25 up 51 min, 0 users, load average: 0.48, 0.56, 0.39
Memory
  • RAM :- Used: 27.26%
    • Total :- 975.61 MB
    • Used :- 265.99 MB
    • Free :- 709.62 MB
  • Swap :- Used: 0.00%
    • Total :- 100 MB
    • Used :- 0 B
    • Free :- 100 MB
      Write Load Period
Disk
  • / :- Used: 31.36%
    • Total :- 7.86 GB
    • Used :- 2.46 GB
    • Free :- 5.03 GB
    • Write Load :- n/a
  • /var/opt/emoncms :- Used: 9.71%
    • Total :- 21.11 GB
    • Used :- 2.05 GB
    • Free :- 17.99 GB
    • Write Load :- n/a
  • /boot :- Used: 20.65%
    • Total :- 252.05 MB
    • Used :- 52.05 MB
    • Free :- 200 MB
    • Write Load :- n/a
  • /var/log :- Used: 4.59%
    • Total :- 50 MB
    • Used :- 2.3 MB
    • Free :- 47.7 MB
    • Write Load :- n/a
HTTP
  • Server :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
  • Version :- 5.5.5-10.3.17-MariaDB-0+deb10u1
  • Host :- localhost:6379 (127.0.0.1)
  • Date :- 2019-11-17 10:11:24 (UTC 01:00‌​)
  • Stats :- Uptime: 127105 Threads: 17 Questions: 3496 Slow queries: 0 Opens: 80 Flush tables: 1 Open tables: 74 Queries per second avg: 0.027
Redis
  • Version :-
    • Redis Server :- 5.0.3
    • PHP Redis :- 5.0.2
  • Size :- 521 keys (970.88K)
  • Uptime :- 1 days
MQTT Server
  • Version :- Mosquitto 1.5.7
  • Host :- localhost:1883 (127.0.0.1)
PHP
  • Version :- 7.3.11-1~deb10u1 (Zend Version 3.3.11)
  • Modules :- apache2handler | calendar v7.3.11-1~deb10u1 | Core v7.3.11-1~deb10u1 | ctype v7.3.11-1~deb10u1 | curl v7.3.11-1~deb10u1 | date v7.3.11-1~deb10u1 | dom v20031129 | exif v7.3.11-1~deb10u1 | fileinfo v7.3.11-1~deb10u1 | filter v7.3.11-1~deb10u1 | ftp v7.3.11-1~deb10u1 | gd v7.3.11-1~deb10u1 | gettext v7.3.11-1~deb10u1 | hash v7.3.11-1~deb10u1 | iconv v7.3.11-1~deb10u1 | json v1.7.0 | libxml v7.3.11-1~deb10u1 | mbstring v7.3.11-1~deb10u1 | mosquitto v0.4.0 | mysqli v7.3.11-1~deb10u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 | openssl v7.3.11-1~deb10u1 | pcre v7.3.11-1~deb10u1 | PDO v7.3.11-1~deb10u1 | pdo_mysql v7.3.11-1~deb10u1 | Phar v7.3.11-1~deb10u1 | posix v7.3.11-1~deb10u1 | readline v7.3.11-1~deb10u1 | redis v5.0.2 | Reflection v7.3.11-1~deb10u1 | session v7.3.11-1~deb10u1 | shmop v7.3.11-1~deb10u1 | SimpleXML v7.3.11-1~deb10u1 | sockets v7.3.11-1~deb10u1 | sodium v7.3.11-1~deb10u1 | SPL v7.3.11-1~deb10u1 | standard v7.3.11-1~deb10u1 | sysvmsg v7.3.11-1~deb10u1 | sysvsem v7.3.11-1~deb10u1 | sysvshm v7.3.11-1~deb10u1 | tokenizer v7.3.11-1~deb10u1 | wddx v7.3.11-1~deb10u1 | xml v7.3.11-1~deb10u1 | xmlreader v7.3.11-1~deb10u1 | xmlwriter v7.3.11-1~deb10u1 | xsl v7.3.11-1~deb10u1 | Zend OPcache v7.3.11-1~deb10u1 | zlib v7.3.11-1~deb10u1
Pi
  • Model :- Raspberry Pi 3 Model B Rev 1.2 - 1GB (Sony UK)
  • Serial num. :- 98B6168C
  • Temperature :- 44.01°C - 45.1°C
  • emonpiRelease :- emonSD-17Oct19
  • File-system :- read-write
Client Information
Client Information
HTTP
  • Browser :- Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:70.0) Gecko/20100101 Firefox/70.0
  • Language :- de,en-US;q=0.7,en;q=0.3
Window
  • Size :- 1903 x 939
Screen
  • Resolution :- 1920 x 1080
Hello @Luiflm2
I cant seem to replicate this here, I’ve created a public dashboard with a grey box right up to the top and left edges and then a white box just offset and a dial, seems to work fine in the different dashboard view modes:
Could you try to see if the space appears creating a test dashboard in the same way? If you can describe the steps I need to take to replicate the issue that would be great.
You could try changing the top bar height with a custom modification to this line here: https://github.com/emoncms/emoncms/blob/master/Lib/misc/sidebar.css#L63 but it will block the emonpi update mechanism if there are future updates to this file…
I created a new dashboard, unfortunately still the same, but
When I call up the dashboard, the error message is flashed for a very short time:
„Notice. A non well formed numerc value encouted in var/www/emoncms/Lib/misc/nav_functions.php on Line 366“
Have you cleared browser cache and tried it in a private window?
@borpin
Clearing browser cache and Private Windows did not bring any success.
@TrystanLea
An update to 10.1.13 didn’t bring any success either.
I am grateful for every idea
Have you tried different browsers?
For me,
Logged out…
Logged in
Look pretty much the same.
Chrome browser.
This error suggests an error caused by a module menu file, do you have any modules installed that may not have updated? What do you see under the /var/www/emoncms/Modules directory?
@emrys any ideas how to better catch this error with the navigation?
@TrystanLea. @Luiflm2 posted a config output above and the modules all look up to date to me.
@Luiflm2, could you run an update and post the update log please.
@borpin, I used different browsers, all with the same problem.
@TrystanLea, i checked the /var/www/emoncms/Modules directory, couldn’t detect any differences to the GitHub
@borpin, here the update log
LAST ENTRIES ON THE LOG FILE
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-17Oct19
emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
nothing to commit, working tree clean
Already up to date.
Main Update Script
Date: Mon 18 Nov 16:54:48 CET 2019
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: all
firmware: none
Hardware detected: rfm2pi
git pull /opt/openenergymonitor/emonpi
* master
On branch master
Your branch is up to date with 'origin/master'.
Fetching origin
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
On branch master
Fetching origin
Already up to date.
Start emonhub update script:
emonHub update
git pull /opt/openenergymonitor/emonhub
* emon-pi
On branch emon-pi
Your branch is up to date with 'origin/emon-pi'.
Already up to date.
Failed to restart .service.service: Unit .service.service not found.
- Service
Running emonhub automatic node addition script
[[2]]
Node 2 already present
[[3]]
Node 3 already present
[[4]]
Node 4 already present
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[17]]
Node 17 already present
[[18]]
Node 18 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
[[27]]
Node 27 already present
[[28]]
Node 28 already present
[[29]]
Node 29 already present
Start emoncms update:
Update Emoncms Core
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
Fetching origin
From https://github.com/emoncms/emoncms
* branch stable -> FETCH_HEAD
Already up to date.
Update Emoncms database
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK
emonPi emoncms admin reboot button sudoers updated
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 2.0.1-82-g48fb43b
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/config module
- git tags: 2.0.2-9-g1bba25a
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 2.0.3-41-g3c20c5b
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/device module
- git tags: 2.0.0-22-g46654e9
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 2.0.1-61-gd5ecfbe
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/setup module
fatal: No names found, cannot describe anything.
- git tags:
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 2.0.0-29-g274bcd5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK
wifi sudoers entry updated
Updating /opt/emoncms/modules/backup module
- git tags: 2.0.0-39-g81b5912
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/demandshaper module
- git tags: 1.1-30-g42749d9
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/postprocess module
- git tags: 2.1.0-20-ga9b1516
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/sync module
- git tags: 2.0.1-15-g39361e4
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/usefulscripts module
- git tags:
- no local changes
Already up to date.
Already on 'stable'
emonPi update done: Mon 18 Nov 16:55:16 CET 2019
restarting service-runner
Server Information
Server Information
Services
  • feedwriter :- Active Running - sleep 300s 128 feed points pending write
Emoncms
Server
  • Date :- 2019-11-18 17:01:35 CET
  • Uptime :- 17:01:35 up 32 min, 1 user, load average: 0.11, 0.13, 0.16
Memory
  • RAM :- Used: 28.70%
    • Used :- 280.02 MB
    • Free :- 695.59 MB
    • Total :- 100 MB
    • Used :- 0 B
    • Free :- 100 MB
      Write Load Period
Disk
  • / :- Used: 32.10%
    • Total :- 7.86 GB
    • Used :- 2.52 GB
    • Free :- 4.97 GB
    • Write Load :- 2.5 KB/s (8 mins)
  • /var/opt/emoncms :- Used: 9.73%
    • Total :- 21.11 GB
    • Used :- 2.05 GB
    • Free :- 17.98 GB
    • Write Load :- 584.28 B/s (8 mins)
    • Used :- 52.05 MB
    • Free :- 200 MB
    • Write Load :- 0 B/s (8 mins)
  • /var/log :- Used: 4.41%
    • Total :- 50 MB
    • Used :- 2.2 MB
    • Free :- 47.8 MB
    • Write Load :- n/a
HTTP
MySQL
  • Date :- 2019-11-18 17:01:34 (UTC 01:00‌​)
  • Stats :- Uptime: 69924 Threads: 16 Questions: 1879 Slow queries: 0 Opens: 80 Flush tables: 1 Open tables: 74 Queries per second avg: 0.026
Redis
  • Version :-
  • Size :- 523 keys (851.51K)
  • Uptime :- 0 days
MQTT Server
PHP
Pi
  • Temperature :- 48.31°C - 47.8°C
Client Information
Client Information
HTTP
Window
Screen
Thanks - that (as I expected) has no errors in it.
@TrystanLea or @emrys may be able to solve it.
I’ve created this github issue to track the problem:
This emoncms pull request should fix this issue:
could you let me now if now this doesn’t sort your problem.
I’ve merged @emrys fix to the master branch, could you test @Luiflm2 to confirm it works for you, these are the steps:
cd /var/www/emoncms
git checkout master
git pull
then if you want to switch back to stable after testing:
cd /var/www/emoncms
git checkout stable
git pull
@emrys, @TrystanLea, I just installed the update, it works.:+1::+1::+1:
I thank everyone for quickly solving.
good to hear thanks @Luiflm2
