Further commit to the dashboard Master branch this evening to enhance the Undo/Redo feature.
This change means that if you move something left 5 times, then the undo states are all squashed into one. This is more natural. Similarly if you move things forward or backward multiple times, it’s just one undo state.
The feature has been added to the ‘master’ git branch for wider testing.
Once the openenergymonitor team are satisfied that it works OK, it will be added to the ‘stable’ repo, and at that stage, if you run ‘update’, it will install the feature automatically.
