I created a simple line widget with color based on feed and simple animation support, the widgets are pretty easy to make, I’m sure there are some bugs (I only have a couple hours into it) and I want to add additional features, but I figured people might be interested in it (instead of having to do the transparent background image / led workaround)
Here’s the source:
line_render.zip (1.8 KB)
Just save as /var/www/html/emoncms/Modules/dashboard/widget/line/line_render.js if you want to try it
Edit - saved source code to a .zip file and attached to post.
Please attach your files directly to your post. If the site you linked to becomes unavailable,
your post loses it’s value. BT- Moderator
