Hi All
I have a Daikin Altherma ASHP and Solis S6 PV inverter. I’m looking to purchase a EmonPi Solar Bundle and possibly Daikin LAN adapter to utilise excess solar production. Has anyone done this successfully?
You can get data from the emonPi into home assistant and likely setup rules that would then link through to Daikin. Other’s here or perhaps on the home assistant forum may be able to help more with that than I can…
There’s ESPAltherma, though I’ve no experience.
I’ve just had a Daikin fitted, still tuning the WC curve and getting sensors sorted for logging via Openenergymonitor.
Ive just had a daikin ashp and solis inverter installed. My energy consumption doenst seem right with daily usage of 50kwh.
How mush does ashp use overnight on average when heating and water is not in use?
Any help will be apreciated as im baffled with current usage.
I’m based in Dublin, 175m2 house, have found maximum daily demand in winter to be about 30kWh for whole house (heating, hot water, cooking, lights etc ), in summer it would be 5-10kWh.
Not sure if you have solved the usage but might be worth checking the back up heater is off or that it is set correctly (depending on which model you have).
Hi Mark,
We live off grid with solar power and VRLA batteries and have a Daikin ASHP fitted with a BRP072C42 wifi controller. I use a NodeRed script to modulate the set temperature (and in turn the power consumed) to maximise/limit its operation so that only excess available solar generation is used. The interface with the BRP072C42 is quite straight forward and uses https calls to get the operating status and set the control parameters (eg. power, mode, set temperature, fan speed, fan direction).
Can I help you?
Simon
So… electrician came, changed few settings (dont ask me what!) and the grid consumption has come down to ave 27kwh over the last 3 days which is a relief.
Overall consumption is averaging 50kwh. Does that now seem right?
GF - 118m2 under floor heating
FF - 100m2 radiators
SF - 62m2 radiators
