The Cylinder widget has just been updated in the emoncms dashboard;
- Optimization of the code
- Ability to set the number of decimals
- Choice of unit position (Back/Front/No display)
- The widget now accepts temperature feeds in °F - conversion °F->°C is made in order to benefit from the correct temperature gradient
Many thanks to Aymeric Thibaut for submitting.
To update your dashboard;
Emonpi’s - run the inbuilt update script
Self-Builds - run $git pull from within your emoncms/Modules/dashboard directory
Paul
