CT Sensor not working
Hi all,
I’ve recently purchased a Particle Photon and a CT sensor (SCT013 60A/1V) with a view to monitor the electricity coming into my home. I’ve created a basic prototype of the circuit using a breadboard (which I believe is correct) and have written some very basic code to read in from the connected analogue pin. The value I see from the analogue pin equates to about 1.65V which is correct when no current is present (output on the board is 3.3V and so the two resistors reduce this as expected). The issue is I’m not able to ever get the value to change. I’ve placed the clamp over various power draws (100W light bulb, 4A phone charger) but I can’t get it to move from 1.65V. The CT sensor has continuity between the two wires but it’s like it just isn’t working. From my understanding this model already has a built in burden resistor and should produce up to 1V @ 60A. Am I doing something wrong here? Is there a way to test the CT sensor? Any help would be greatly appreciated.
Mark
Have you got a multimeter that will go down to millivolts a.c? If not, can you connect the c.t. to an audio amplifier and listen to it?
Your 100 W lamp will draw 400 mA, the c.t. output should be 6.6 mV rms, or a peak-peak swing of 18.6 mV, or 23 counts. (All those are approximate.)
If you pass say 10 turns of wire through the c.t., your lamp will look like a 1 kW lamp drawing 4 A, and you’ll get 10× bigger numbers out of it.
How are you processing the values you are reading?
Hi Robert,
Thanks for the reply. I do have a multimeter capable of measuring millivolts AC but am unsure if I’m using the correct points when trying to test the sensor. I have one lead connected to the return wire from the sensor and the other connected to the ground on the Photon.
When testing with this setup using the 100W lamp I am seeing some movement when turning it on (25.8 mV) and off (24.0mV).
I also tested it with a much larger load (2000W hairdryer) and the measurements were as expected and much larger (off = 19.0mV, on = 185.0mV).
This leads me to think the sensor is actually working and maybe my issue is more with interpreting the results.
In terms of processing the values I’m simply reading the value of the analogue pin within a loop that has a 1 second delay. The analogue pin returns an integer between 0 to 4095 which is directly proportional to the voltage measured (3.3V / 4096 units or 0.0008V (0.8 mV) per unit).
With no load the value sits around 2048 when I apply a 2000W load the value ranges between 2030 - 2060. I assume this is because it’s AC.
The sure way to prove the c.t. is with the c.t. disconnected from the electronics.
Your meter might not be rejecting the d.c. component in the voltage at the ADC input.
I’m not sure what that actually means, but I think it’s missing something. Take a look at emonLib. In emonlib.cpp and at line 175, there’s the method to calculate the rms current. I suggest you copy the core part of that. You’ll obviously need to change some of the numbers to suit your ADC. The number of samples should cover an exact number of mains cycles - or enough to make any “end effect” error small enough to disregard.
“Root mean square” is the accepted measurement for alternating voltage and current.
Now I think I’m getting somewhere. There appears to be a port of the emonLib library for the Photon device I’m using.
I’ve had a play but am a little unsure about the values I should be passing in to the functions.
I currently have this which I’m not sure is quite right:
void setup()
  emon1.current(0, 900);
void loop()
  double Irms = emon1.calcIrms(112);
  Particle.publish("current:", String(Irms));
  Particle.publish("watts:", String(Irms*230.0));
I’m in the UK so from my understanding the mains here is approx 230V 50Hz. After reading another one of your posts (Sampling rate of emonLib) I’ve set the value of calcIrms to 112. When initially testing this with the default calibration value of 111.1 the results were way to low when compared to the load being generated, therefore I’ve had to increase this considerably to 900 in order to match the load I’m using for testing. Is this normal or am I doing something wrong here?
What you’re probably doing is not getting close enough to averaging over a complete number of cycles of mains. Even if you know the sampling rate exactly, and nominally have an exact number of samples fitting into one mains cycle, you’ll still have an error as soon as the mains frequency changes as the load on the generators varies. You must expect and tolerate that. If you measure over many cycles, then the longer the averaging time, the less the variation you are likely to encounter.
The fundamental question to determine the number of samples you need is: what is the sampling rate of calcIrms( ) when running on your Proton? You need to know that.
The method is:
Time the period it takes from just before calling calcIrms( ) to just after it returns, using the time-honoured millis( ) function, i.e. unsigned long start = millis( );, and Serial.println(millis( ) - start); after (or it’s equivalent).
Do this for a small number of samples - say 20, for a large number, say 1020, and the difference gives you the time (for 1000 samples) without including the overhead of calling the method and processing the result.
Then choose the nearest number of samples that gives you say 10 cycles (200 ms) of mains. Or longer if you wish.
N.B. I suggest you forget the fallacy of the UK voltage being 230 V. That was an EU standards fudge. As far as I know, the centre voltage is much more likely to be 240 V than 230.
Then, you need to calculate you calibration constant, based on knowing your c.t. ratio and the ADC resolution and reference voltage.
Thanks again for all your help with this Robert.
As you suggested I timed the number of samples collected on the Photon:
  emon1.calcIrms(20)  ->  1
  emon1.calcIrms(1020)  ->  97
With this I’ve calculated the nearest number of samples that give me 10 cycles (200ms):
  1000 samples -> 96
  1000 / 96 * 200 = 2083
Does this look correct?
Passing this value to calcIrms still requires a fairly large adjustment to the calibration value.
  emon1.current(0, 800);
  emon1.calcIrms(2083)
I’ve also updated the mains voltage to 240 as you mentioned.
The number of samples looks believable, but it should not affect the calibration while you keep the number close to an integral number of cycles. If you (say) double the number of samples to cover 400 ms (20 cycles - but the mains won’t always be 50 Hz exactly), you should still read the same value.
Backtracking, you now know that you have 208.3 samples per cycle, so when you were sampling 112/208 of a mains cycle - roughly half, the value you got would heavily depend on where your sampling started and ended.
To get anywhere near the expected load I’m testing with I still need to set a fairly high value of 800 for the calibration. Is this plausible?
This is what I’ve currently coded:
void setup()
void loop()
  double Irms = emon1.calcIrms(2083);
  Particle.publish("watts:", String(Irms*240.0));
One downside to the high calibration value is when there’s no load the idle values are reasonably high.
watts:	91.258529
current:	0.380244
Does it make sense to compensate this by subtracting these idle values from the calculated ones?
It doesn’t look right to me. You need to do the maths. Your c.t. gives you 1 V per 60 A, and your input is 4095 counts per 3.3 V?
Therefore 1 count represents 60 × 3.3 ÷ 4095 A = 48.47 mA. This is I_RATIO inside emonLib (= 0.04847). You seem to need a value of 0.644
Have you checked that emonLib is getting the correct value for ADC_COUNTS?
What resistance do you measure for your c.t? I think it should be the winding resistance (≈ 90 Ω) in parallel with ≈ 31 Ω, so I’d expect about 23 Ω.
That’s correct. My CT is 1 V / 60 A (YHDC SCT013).
The resistance of the CT measures 23.4 ohms as you calculated.
The input pin also has 4095 counts per 3.3 V.
The ADC_COUNTS has a constant value of 4096.
When the CT sensor has no load I’m seeing an analog count value of 2046 which I believe makes sense due to the halving of the 3.3 V.
All those numbers are as I thought they should be, but I can’t quite see why your calibration of 800 should be correct! It doesn’t fit with the processing inside emonLib, unless emonLib is finding a wrong number from somewhere, which it is using in the calculations.
If 800 gives you the correct answers and it’s linear, then use it.
I’m an idiot! After re-reading this excellent article Learn | OpenEnergyMonitor I’ve noticed that I have the CT sensor wired incorrectly. I’ve now corrected this and everything seems much better (I’ve had to actually reduce the calibration values down to 60 (hoping this is normal for some setups)).
Thanks for all your help with this, there’s no way I could have got things up and working without you!
If you could, tell us what it was you did to resolve the issue.
That way, if someone else makes the same error, they’ll be able to find a solution.
Thanks!
That is exactly the value that you should have.
And yes, knowing what your mistake was will help us because it will enable us to look out for it when someone has a similar problem in the future.
The problem is best described if you reference the picture of the circuit I initially posted above with the one below.
The hook-up of the CT sensor was completely wrong and I was grounding the input pin with a capacitor. The input pin should simply be one of the cables from the CT sensor. The other cable from the CT sensor (the ground) goes via a capacitor but has a 1.65 V feed to it.
I searched the internet for clear images of a real-world working circuit (not circuit diagram) but wasn’t able to find one. Hopefully the picture above will help someone.
Thanks again for all your help. Much appreciated!
Here’s the original picture again:
That would almost totally kill the output, which explains everything. Being able to transcribe a circuit diagram to the breadboard is an essential skill. Not knowing nor having looked up the pin connections for your board, I’d never have spotted that.
