CT 3.5mm jack
I just got a couple of SCT006 and unfortunately are the wires not connected to a 3.5mm plug, I’ve looked at the schematics of IoTaWatt and have a hard time understanding how I should wire the CT’s (is it tip+gnd?).
Also, I’m part of the “handful of three phase users”, just so you know :slight_smile:.
Found this: https://www.sparkfun.com/datasheets/Sensors/Current/2009511142810295.gif so I’m good :stuck_out_tongue:
I connected some HWCT-004 CTs the same way and all worked as expected. Glad you found the sparkfun data sheet. I felt like I was guessing!
