Hi all,
I’m having some difficulty setting up a daily kWh consumption graph on my dashboard. I have a cumulative kWh feed generated from the optical pulse sensor, and I can very easily create the exact graph that I need in the Visualization section of Emoncms, but replicating the same settings does not seem to work in the dashboard.
These settings show me exactly what I want as a Visualization:
feed: kwh_pulsecount
interval: 86400
dp: 1
scale: 1
delta: On
mode: 0
Using those exact same settings in the dashboard just gives me an empty graph. I have also tried with mode “On” and a blank interval, but that made no difference.
Does anyone have any guidance on creating a daily kWh bargraph on the dashboard, or any insight in to why it might not be working?
I’m currently running Emoncms low-write 10.2.6
Thanks!
