I’ve got a Pi running emonSD and this same Pi has a couple of DS18B20 temperature sensors running with a Python script. This Pi is in a place with no wifi or bluetooth. Is there a way to send the DS18B20 temperature data to the emon server internally, without using the HTTP input API? (or MQTT). This has got to be easy, but I’m not seeing a solution.
You need this direct-ds18b20-temperature-sensing
