I don’t think you can do this in Emoncms. Could you use the pulse input on the emonTx / emonPi / emonTH to count the transitions then log this to an ‘accumulator’ feed in Emoncms?
Hello,
How did you send the data from the rotex to emoncms?
I have a rotex too and I would like to make some dashbord like you.
I have installed pyhpsy on a raspberrypi and also emoncms but I cannot recieve anything in emoncms…
Could you help me please?
Note : the installation of emoncms on the rasberry seems to be ok, the only thing that I was not able to install is the swiftmailer.
pyHPSU is working fine and using it with the command line return correct values too.
