Cosy Heat Pump Hush Mode Stats
Did some testing today with the Cosy 6 with Hush mode turned on and off. Results below. For the Hush mode off test, the ambient temp did drop by a couple of degrees from the prior test.
That’s really interesting. Are you heating the DHW as a test source? And what did you notice about the sound levels?
I was wondering about how the silent/hush mode would work on a 5kW Vaillant Arotherm+.
If you decrease the maximum heat output, then you are going to get cold sometimes.
My heatpump is maybe 30% oversized which is a good place to be I believe.
I was wondering if silent mode is in anyway like running with the next lower model (3.5kW version). I guess any heat curve setting would have to be rejigged to keep the house comfortable and may not work in very cold weather.
Having said that we are nice and cosy here 24/7 so no tinkering is currently permitted !
Nick
I have a 5kw Aerotherm+ and have been running it in quiet mode for the last 2 years. It has worked fine. The coldest outside temperature was -9c and it was a long way from being maxed out with a system temp of 45c at that point. Heating curve is set to 0.5
Hi Nigel. That’s interesting. I’m always worried about changing things that work.
Does it run at better efficiency do you think ?
Have you compared COP’s for silent vs standard for the same outside/indoor conditions ?
My HP generally cycles down to about 5C before it runs constantly. How does that compare to yours?
As is the usual case the system design is a bit off at [email protected],21C, but seems more like [email protected]. The survey also claimed output at DOT is supposed to be 6.1kW, which I think we know is probably not achievable in reality due to defrost and is more like the badge value 5kW max.
Cheers,
Nick
Are those Octopus Cozy data from their cloud backend or you somehow gathered locally?
I’m looking at heat pump install, but dislike reliant on the cloud. If I want local control, does this completely rule out Cozy heat pumps?
Last year and winter I ran ‘Quieter’ mode on Daikin Altherma 3 8kW.
This spring, summer and so far it’s been on ‘Most Quiet’ setting.
‘Most Quiet’ definitely gives better COP all year round for DHW.
Likewise the shoulder months when its not that cold.
Jury is out on COP for the full winter.
We’ve had -2°C overnight so far wirh no problems heating the house to normal desired temps.
The thing is oversized, but modulates down quite well.
Design was 50°C at -3°C​:rofl: (Octopus’ totally over safe and over dimensioning).
We actually run the weather curve 44°C at -9°C and it’s great.
External temp sensor mounted 5cm off brick wall in full sunlight - it actually responds to the solar gain we get nicely and as soon as the sun goes in cools off in line to.
Gas usage was ~12000kWh annually for heating and DHW.
Heatpump achieved 2370kWh last rolling year, for better comfort and same DHW provision.
As gas prices rise it’s looking a better and better thing pennies wise.
I’ll continue to monitor Most Quiet mode..
The main effect seems to be on the hot water run. Definitely stretches that out taking about twice as long. Water run works harder as you can just hear the fan which is visible moving more air. On heating it is effectively silent which is the main effect I was after.
