I have a corrupt sd card from something i have done, is there anyway i can recover it or does it have to be reflashed. Basically i don’t think i let something finish installing and now it will not boot.
Your best bet will be to either get a pre-flashed card or one off Amazon and flash yourself.
You can then use the update process to try and recover the data and settings (which is highly likely).
I can’t find the update process in the docs currently - @TrystanLea
Found it, perhaps not best location though
https://docs.openenergymonitor.org/emoncms/import.html#import-using-a-usb-sd-card-reader
Thanks Brian I ordered a new card last night so hopefully will be here tomorrow. I am also going to try and flash one as well as a spare.
