Connecting Axioma E4 heat meter to Home Assistant Green without emonPi
Hi all,
I’m in the process of ordering an Axioma Qalcosonic E4 DN25 heat meter for my 12kW Vaillant aroTHERM Plus heat pump and want to get the data directly into Home Assistant without needing an emonPi or emonBase.
My current setup:
  • Home Assistant Green (HA OS)
  • myPyllant integration for Vaillant data
  • Shelly Pro EM already measuring electrical input to the HP
  • Shelly temperature sensors on flow/return and UFH manifold
  • ESPHome already in use (running a BLE Bluetooth proxy)
  • MQTT broker running in HA
What I want:
  • Heat output in kW (live) and kWh (daily) from the E4
  • Feed into HA sensors for COP calculation and dashboard display
  • Ideally fully local, no cloud
What I’ve considered:
  • OEM M-Bus to USB adapter plugged into HA Green’s USB port — but unclear if this works without emonPi
  • ESP32 + M-Bus transceiver board as a WiFi bridge via ESPHome — seen this mentioned but described as complex
  • Pi Zero 2W running emonSD as a bridge — works but adds another device
Questions:
  1. Has anyone connected the OEM M-Bus USB adapter directly to HA Green (no emonPi) and got it working?
  2. Is there a straightforward ESPHome M-Bus config that works with the Axioma E4?
  3. Is there a simpler solution I’m missing entirely?
Happy to share more about my setup. Thanks in advance!
Hi, welcome.
You don’t need an emonPi, but you do need some way of reading the output from the M-Bus adapter.
You could do this with a normal Pi (of any flavour, including the Zero) with emonhub installed. This could send the data to an MQTT topic for HA to consume. emonHub Interfacers — OpenEnergyMonitor 0.0.1 documentation
[edit]
If you search for ESPHome M-Bus there are some interesting results.
Please let us know what your solution is :slight_smile:
Hi Brian, thanks for the quick response and the links.
I’ve had a look through the emonHub interfacers documentation and it’s starting to make more sense. I can see there’s a config example for the Qalcosonic E3 — I’m buying the E4 (DN25 QP3.5). Is the emonHub config the same for the E4, or does it need a different meter type setting?
I’m thinking the simplest route for me would be:
  • OEM M-Bus to USB converter
  • emonHub reading the meter and publishing to MQTT
  • My existing HA MQTT broker picking it up directly
A few questions before I order anything:
  1. Is the Pi Zero 2W powerful enough to run emonSD reliably for just this one task?
  2. Does emonHub publish directly to MQTT out of the box, or does it need additional configuration to do that?
  3. Is there a straightforward step-by-step guide for setting this up from scratch on a Pi Zero 2W that doesn’t assume too much prior knowledge?
My Home Assistant is running on a Home Assistant Green so I can’t run emonSD on that directly.
Did you search for ESPHome and M-Bus? There are a number of solutions that may work especially if you already have an ESP lying about.
I’d be inclined to simply flash the Pi with an OS Lite image and install emonhub directly. emonHub Overview — OpenEnergyMonitor 0.0.1 documentation. The emonSD adds complexity you don’t need.
Yes, but yoOh dearOh u would have to configure emonhub for the Heat Meter and to send to MQTT
As this isn’t a normal setup, there is no direct guide except what I just posted.
Hi Brian, thanks again for the advice.
I’ve done a bit more research and found an existing thread on the OEM community where someone set up an Axioma Qalcosonic E4 with emonHub. Glyn confirmed that for the E4 the correct emonHub config uses type = standard rather than type = qalcosonic_e3 as shown in the docs.
I’m going to go with the Pi OS Lite + emonHub route as you suggested rather than emonSD. I have a spare Raspberry Pi 4 8GB which I’ll use for this.
A few follow up questions:
  1. Is there a recommended step by step guide for installing emonHub on a fresh Pi OS Lite install? I’m reasonably comfortable with Raspberry Pi but don’t want to assume too much.
  2. For the MQTT output — can you point me to the correct config section to add so emonHub publishes to my existing HA MQTT broker rather than a local one? I can see in the thread that MQTT is configured in emonhub.conf but I want to make sure I point it at the right host/port.
  3. One thing I noticed in the thread — there’s a one-time step to set the meter address using a script. Is this still required with a fresh E4 out of the box, or does it default to address 1 automatically?
Thanks again — really appreciate the patience with a non-expert!
See the links above.
I don’t know - @glyn.hudson is the expert on these devices.
Yes, this is required. You can run this script to set the MBUS address: usefulscripts/mbus/mbus_set_address.py at master · emoncms/usefulscripts · GitHub
This is the emonhub config for reading from Axioma, and most other MBUS heat meters. The E4 and E3 are identical, the only difference is the brass vs composite body of the flow meter.
    [[MBUS]]
        Type = EmonHubMBUSInterfacer
        [[[init_settings]]]
            device = /dev/ttyUSB0
            baud = 2400
        [[[runtimesettings]]]
            pubchannels = ToEmonCMS,
            read_interval = 10
            validate_checksum = False
            nodename = heatpump
            [[[[meters]]]]
                [[[[[heatmeter]]]]]
                    address = 1
                    type = standard
The PiZero should be plenty powerful enough. Using emonSD make the setup plug and play. But installing emonhub yourself on a bare Raspbian lite image will result in a more streamline system, e.g without Emoncms or MYSQL, but there will be more setup work.
ill be looking to do the same with a e4 heat meter. I have home assistant running on its on dell nuc proxmox vm. Have a spare rasperry pi around as well - is there a modbus to wifi connector i could use to get the heat meter into home assistant? i’ve a shelly em50 pro for the electricity usage and that will integrate easy enough
i have one of these lying around - https://lilygo.cc/en-us/products/t-can485?srsltid=AfmBOoo9iTPYGWhwwmUIz-MzPdPSy5kWwwjAclKBBNP2kXZPMe9z24Ia
Would it work to connect the modbus to home assistant?
Hi Michael
Ive ordered this along with the Heat Meter. M-Bus to USB Converter | HeatPump Monitoring - Shop | OpenEnergyMonitor
should be fun trying to make it all work.
For what it’s worth:
The default M-Bus primary address on the E4 meters is the last two or three digits of the serial number.
001
002
003
250
251
252
You can also set primary address 254 on the readout code (this is the Spartacus address - every meter will respond to the Spartacus address) if you only have ONE wired M-Bus device attached. That will work regardless of the primary address that has been set.
That is really useful info - @glyn.hudson in case you miss it.
Primary address 254 is the “quick hack” that can bite you in the bum later when you forget that it ONLY works when ONE M-Bus device is connected.
Probably the most robust method is to use secondary addressing, run an M-Bus wildcard search by secondary address, and auto-create the meters that you find. That way “address 12345678” is always the address printed on the meter in a multi-meter setup; rather than needing to remember to set the first meter as 001 and the second one as 002 and the third as 003 etc and then remember that primary address 001 is meter 12345678 and primary address 002 is meter 99999999 etc.
Hi Marko, so there is a way to do this with multiple meters and it won’t cause a conflict with multiple meters responding at once?
Not sure what your question is @Gwil
M-Bus offers two ways of addressing meters:
Primary addressing (where you set an address on the meter from 000 to 250 then use this to read the meter) and Secondary addressing (where you just use the secondary address of the meter which is an 8 digit value generally factory set as equal to the serial number of the meter)
Primary 254 is a special address that ALL meters will respond to. You can’t have more than one meter respond at the same time so this can only be used when there is just one meter on the M-Bus network.
Secondary addressing is the industry standard these days. You can safely connect a number of meters up to the same network then address it using the serial number printed on the front. All modern meter support wildcard searching so you can “search the bus” for all meters present and then begin reading them out. You don’t have to worry* about two meters having the same address as you do with primary addressing.
*Each manufacturer can have from 00000000 to FFFFFFFF as serial numbers. The combination of manufacturer flag ID (https://www.dlms.com/flag-id/) and serial is globally unique. It is IMPOSSIBLE to have two meters from the same manufacturer code with the same secondary. It is very unlikely to have to meters from different manufacturers with the same secondary.
Thanks, Marko.
This is the bit I was trying, ineloquently, to get at. When you have an unknown number of meters on the M-Bus network and you ask them to identify themselves, there is a way for them to - reliably -all reply and the messages don’t all get mixed up and cause a conflict.
So if I set up x number of E4 meters on an M-Bus network and asked you to tell me the total number I have and give the secondary addresses for each, that can be done?
Understood!
Yes.
Primary addressing won’t cut it.
Secondary addressing will for certain (if all are from the same manufacturer) and “almost certainly” even in other cases even if you just wildcard the serial rather than the manufacturer. “Wildcard search” is what you need when using secondary addressing to do this:
Say you have two meters:
11111111
11111121
“All meters 0******* please respond” > no response
“All meters 1******* please respond” > clash
“All meters 11****** please respond” > clash
“All meters 111***** please respond” > clash
“All meters 1111**** please respond” > clash
“All meters 11111*** please respond” > clash
“All meters 111111** please respond” > clash
“All meters 1111111* please respond” > “hello, I am 11111111”
“All meters 1111112* please respond” > “hello, I am 11111121”
“All meters 1111113* please respond” > no response
“All meters 1111114* please respond” > no response
“All meters 1111115* please respond” > no response
“All meters 1111116* please respond” > no response
“All meters 1111117* please respond” > no response
“All meters 1111118* please respond” > no response
“All meters 1111119* please respond” > no response
“All meters 2******* please respond” > no response
“All meters 3******* please respond” > no response
“All meters 4******* please respond” > no response
“All meters 5******* please respond” > no response
“All meters 6******* please respond” > no response
“All meters 7******* please respond” > no response
“All meters 8******* please respond” > no response
“All meters 9******* please respond” > no response
etc
That’s how you search the larger space offered by secondary addressing without it taking a lifetime.
If you have a Windows machine try downloading Izar@Net from here; hooking up a USB>M-Bus dongle; hooking a couple of meters to that; and watching how it searches:
MBCONF can be used (windows machine and USB>M-Bus dongle) to see how address 254 will read “any” meter. It can also be used to set the primary address of a meter to something else if you’ve picked up some random stuff from eBay etc.
I am using ESPHome on an M5Stack Atom Esp32 + 2 * Atomic RS485 Base and had to buy a RS485 to Mbus Master converter from AliExpress. Same Esp32 is connected to the Eastron meter via Modbus to get the acurate electric Heatpump usage data.
Configured Homeassistant to send the required data to locally hosted Emoncms.
Using below custom ESPHome component and works very good.
Thanks, @Marko_Cosic - this is amazing! Found a tool called libmbus so I could test this quickly on my Linux laptop, lo and behold it found the two meters I had connected:
/usr/local/bin/mbus-serial-scan-secondary -b 2400 /dev/ttyUSB0
Found a device on secondary address 0403715209070C0D [using address mask 040371FFFFFFFFFF]
Found a device on secondary address 0403732609070C0D [using address mask 040373FFFFFFFFFF]
Enjoy the “autoconfigure” hack @Gwil ! :grin:
Libmbus is excellent for a free piece of software and probably plenty for modern meters only; but may annoy you with its size and lack of some features if you really get into M-Bus. We roll our own secondary search code in production applications for tighter control of the initialisation commands and timings than can be needed for some older meters and meters that have chinesium levels of standards compliance. (e.g. Eastron!)
