I have an EmonPi. I cannot get data to Node-Red using MQTT.
I had configured the server as the next image shows:
But it doesn’t work.
This is the mosquitto log:
pi@emonpi:/var/log/mosquitto $ tail mosquitto.log 1576698856: Config loaded from /etc/mosquitto/mosquitto.conf. 1576698856: Opening ipv4 listen socket on port 1883. 1576698856: Opening ipv6 listen socket on port 1883. 1576698858: New connection from 127.0.0.1 on port 1883. 1576698858: New client connected from 127.0.0.1 as lwrf (c1, k20, u'emonpi'). 1576698858: New connection from ::1 on port 1883. 1576698858: New client connected from ::1 as emoncms (c1, k5, u'emonpi'). 1576698859: New connection from 127.0.0.1 on port 1883. 1576698859: New client connected from 127.0.0.1 as 2a95e7ad-8efc-4032-8e0f-b8660f6b36bc (c1, k60, u'emonpi'). 1576698865: New connection from 127.0.0.1 on port 1883.
But it is always in “connecting” state:
This is the node-red log:
pi@emonpi:/var/log $ node-red-log
18 Dec 19:54:24 - [info] Started flows
18 Dec 19:54:25 - [info] Server now running at http://127.0.0.1:1880/
18 Dec 19:54:25 - [info] [mqtt-broker:EmonHub] Connection failed to broker: mqtt://emonhub/rx/#:1883
18 Dec 19:54:49 - [info] [mqtt-broker:EmonHub] Connection failed to broker: mqtt://emonhub/rx/#:1883
18 Dec 19:55:04 - [info] [mqtt-broker:EmonHub] Connection failed to broker: mqtt://emonhub/rx/#:1883
18 Dec 19:55:19 - [info] [mqtt-broker:EmonHub] Connection failed to broker: mqtt://emonhub/rx/#:1883
Do you have any idea to solve this problem?
Thanks a lot
