Code test:
EmonTx Shield 4 x CT example
An example sketch for the emontx Arduino shield module for
CT only electricity monitoring.
Part of the openenergymonitor.org project
Licence: GNU GPL V3
Authors: Glyn Hudson, Trystan Lea
Builds upon JeeLabs RF12 library and Arduino
emonTx documentation: http://openenergymonitor.org/emon/modules/emontxshield/
emonTx firmware code explination: http://openenergymonitor.org/emon/modules/emontx/firmware
emonTx calibration instructions: http://openenergymonitor.org/emon/modules/emontx/firmware/calibration
THIS SKETCH REQUIRES:
Libraries in the standard arduino libraries folder:
- JeeLib https://github.com/jcw/jeelib
- EmonLib https://github.com/openenergymonitor/EmonLib.git
Other files in project directory (should appear in the arduino tabs above)
- emontx_lib.ino
/*Recommended node ID allocation
-ID- -Node Type-
0 - Special allocation in JeeLib RFM12 driver - reserved for OOK use
1-4 - Control nodes
5-10 - Energy monitoring nodes
11-14 --Un-assigned --
15-16 - Base Station & logging nodes
17-30 - Environmental sensing nodes (temperature humidity etc.)
31 - Special allocation in JeeLib RFM12 driver - Node31 can communicate with nodes on any network group
#define FILTERSETTLETIME 5000 // Time (ms) to allow the filters to settle before sending data
const int CT1 = 1;
const int CT2 = 1; // Set to 0 to disable
const int CT3 = 1;
const int CT4 = 0;
#define RF_freq RF12_433MHZ // Frequency of RF12B module can be RF12_433MHZ, RF12_868MHZ or RF12_915MHZ. You should use the one matching the module you have.
//const int nodeID = 6; // emonTx RFM12B node ID
const int nodeID = 17; // emonTx RFM12B node ID
const int networkGroup = 210; // emonTx RFM12B wireless network group - needs to be same as emonBase and emonGLCD
#define RF69_COMPAT 1 // set to 1 to use RFM69CW
#include <JeeLib.h> // make sure V12 (latest) is used if using RFM69CW
#include "EmonLib.h"
EnergyMonitor ct1,ct2,ct3, ct4; // Create instances for each CT channel
typedef struct { int hora, power1, power2, power3, power4, TEMP1 ;} PayloadTX; // create structure - a neat way of packaging data for RF comms, nothing is added a a 5th integer to match data structure of voltage version
PayloadTX emontx;
const int LEDpin = 9; // On-board emonTx LED
boolean settled = false;
int x;
// TEMPERATURA
#include <OneWire.h>
#include <DallasTemperature.h>
OneWire oneWire(4); // Setup one-wire on digital input pin 4
DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature.
DeviceAddress address_T1 = { 0x28, 0xFD, 0xBE, 0xBC, 0x07, 0x00, 0x00, 0x32 };
