hello all,
i have succesfully programmed the boards but one of them is showing way to low voltage. when i give the measured voltage and press calculate it says devider can not go higher then 5. Any suggestions ?
What can i check ? i have resoldered the attiny and visually checked the board seems fine
thanks all
