Can't update database structure because the changes won't let me access the admin page
So I’m stuck. What I really need is a url/command that calls the database update routine directly rather than from the admin page which I am unable to access due to the changes. I can’t work it out from looking at the available .php files The new version is: V9.8.31 | 2018.06.21
I am running this on a remote linux server, not on emonPi.
Any help would be much appreciated.
Please have a look at 5.1: emoncms/Upgrading.md at master · emoncms/emoncms · GitHub
Hope that helps.
Thanks. It does help, but invoking the db update directly doesn’t fix it cos it says there is nothing to update! So I guess it’s not that and I need to reinstall it in another directory. Will let you know how I get on.
Regards
Yes this is an issue (another one @TrystanLea).
This should sort it out.
Cannot login after updating to 9.8.29 (master branch) - #2 by borpin
