Hello,
I have Home Assistant configured to manage the Wi-Fi Relay that controls a water heater. I use the OEM integration for HA.
I need to change the max and min temperatures but I can’t because the entity does not have a unique ID.
I tried to solve this issue but I couldn’t set max and min temperatures neither set a unique ID in the configuration.yaml.
Is there a solution to set this temperatures?
Are you planning to add the unique_id parameter in the integration? This will be very useful because you can use the UI to set this values.
Hope you can help me on this. Thank you!
