Wanted to try logging to the serial monitor, so trying to compile the esp code using platformio. Is this what you are using ? Or the Arduino platform? As per the readme, I pulled the code, entered the EmonESP folder. If I try just a pio run i am told that there is no emonesp environment, which is true. There is no definition for one in the platformio.ini file - there is in the upstream project. Since this is an Esp32 I changed the default to emonesp32 which does exist and tried to compile again with pio run I then get compile errors
compilation terminated.
*** [.pio/build/emonesp32/src/web_server.cpp.o] Error 1
src/energy_meter.cpp: In function 'void energy_meter_loop()':
src/energy_meter.cpp:175:29: warning: variable 'totalVoltage' set but not used [-Wunused-but-set-variable]
float voltageA, voltageC, totalVoltage;
In file included from src/http.cpp:32:0:
/Users/chris/.platformio/packages/framework-arduinoespressif32/libraries/WiFiClientSecure/src/WiFiClientSecure.h:29:1: error: expected class-name before '{' token
/Users/chris/.platformio/packages/framework-arduinoespressif32/libraries/WiFiClientSecure/src/WiFiClientSecure.h:105:18: error: type 'Print' is not a base type for type 'WiFiClientSecure'
using Print::write;
src/http.cpp: In function 'String get_https(const char*, const char*, String, int)':
src/http.cpp:63:12: error: 'class WiFiClientSecure' has no member named 'print'
client.print(String("GET ") + url + " HTTP/1.1\r\n" + "Host: " + host +
src/http.cpp:75:28: error: 'class WiFiClientSecure' has no member named 'readStringUntil'
String line = client.readStringUntil('\r');
*** [.pio/build/emonesp32/src/http.cpp.o] Error 1
