I click on Setup > Emonhub, which takes me to http://emonpi.local/emoncms/config/view.
I click on Download Log, and I get a file which contains only the following line:
/var/log/emonhub/emonhub.log does not exist!
Instead of the actual logs.
See this thread (specifically the last line of the last post):
Assuming you are on an EmonPi, run the EmonPi update and it should correct the issue.
There has been no changes to the emoncms/config repo since that “we still need to fix” post was written.
The code still tries to access the log file that no longer exists
OK, I mistakenly thought I was still seeing the emonhub.log in the logs folder (can’t check) but that the logging was being replicated in the syslog thus exacerbating the filling up log folder issue.
