Hi all - I am extremely frustrated that I can’t seem to create inputs.
Background on my setup: I bought the emonbase and the emontx when it was first released several years ago. I set it up by adding the inputs corresponding to the CT sensors (all 4) and it was running for several years, logging to emoncms.org, no problem.
A couple of months ago, I bought an additional emontx unit so that I could log data for more circuits. I edited the device in emoncms.org but it was giving me bogus values for the inputs. So I figured my emonbase was out of date, and I updated it to the latest, so now I have the emoncms running on it.
There appears to be no way to create inputs for all of the CT sensors. The new device template setup doesn’t seem to have a device that has all 4 CT sensors. That would be OK if there were a way to manually create them but there isn’t as far as I can tell. There also doesn’t seem to be a way to add an additional emontx. Is this stuff supposed to be auto-discovered or something? Do I need newer emonbase hardware?
Frustrating because it was working for years without needing to touch it, and now with an expansion of the system it is completely down.
