No, there are no errors … from the log i can see that data is received and posted locally every 10 seconds as setup in the input but is posted to my cms every 3 reading:
2018-05-29 13:23:12,518 INFO MQTT Publishing: emonhub/rx/8/values 583,558,3465,0,263.36,300,300,300,300,300,300,0,-80
2018-05-29 13:23:15,000 DEBUG emoncmsorg Buffer size: 3
2018-05-29 13:23:15,001 INFO emoncmsorg sending: http://10.1.3.242/html/emoncms/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1527600172.476953,8,582,556,3474,0,263,300,300,300,3 00,300,300,0,-81],[1527600182.410771,8,582,571,3467,0,263.2,300,300,300,300,300,300,0,-80],[1527600192.300197,8,583,558,3465,0,263.36,300,300,300,300,300,300,0,-80]]&sentat=1527600195
2018-05-29 13:23:15,039 DEBUG emoncmsorg acknowledged receipt with 'ok' from http://10.1.3.242/html/emoncms
2018-05-29 13:23:22,151 DEBUG RFM2Pi 13208 NEW FRAME : OK 8 69 2 58 2 149 13 0 0 144 102 184 11 184 11 184 11 184 11 184 11 184 11 0 0 0 0 (-80)
2018-05-29 13:23:22,154 DEBUG RFM2Pi 13208 Timestamp : 1527600202.15
2018-05-29 13:23:22,155 DEBUG RFM2Pi 13208 From Node : 8
2018-05-29 13:23:22,156 DEBUG RFM2Pi 13208 Values : [581, 570, 3477, 0, 262.56, 300, 300, 300, 300, 300, 300, 0]
2018-05-29 13:23:22,157 DEBUG RFM2Pi 13208 RSSI : -80
2018-05-29 13:23:22,158 DEBUG RFM2Pi 13208 Sent to channel(start)' : ToEmonCMS
2018-05-29 13:23:22,159 DEBUG RFM2Pi 13208 Sent to channel(end)' : ToEmonCMS
2018-05-29 13:23:22,376 DEBUG MQTT Publishing: emon/emontx3/power1 581
2018-05-29 13:23:22,378 DEBUG MQTT Publishing: emon/emontx3/power2 570
2018-05-29 13:23:22,380 DEBUG MQTT Publishing: emon/emontx3/power3 3477
2018-05-29 13:23:22,382 DEBUG MQTT Publishing: emon/emontx3/power4 0
2018-05-29 13:23:22,384 DEBUG MQTT Publishing: emon/emontx3/vrms 262.56
2018-05-29 13:23:22,386 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-05-29 13:23:22,388 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-05-29 13:23:22,390 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-05-29 13:23:22,392 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-05-29 13:23:22,394 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-05-29 13:23:22,397 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-05-29 13:23:22,399 DEBUG MQTT Publishing: emon/emontx3/pulse 0
2018-05-29 13:23:22,401 DEBUG MQTT Publishing: emon/emontx3/rssi -80
2018-05-29 13:23:22,403 INFO MQTT Publishing: emonhub/rx/8/values 581,570,3477,0,262.56,300,300,300,300,300,300,0,-80
2018-05-29 13:23:32,070 DEBUG RFM2Pi 13209 NEW FRAME : OK 8 71 2 54 2 135 13 0 0 202 102 184 11 184 11 184 11 184 11 184 11 184 11 0 0 0 0 (-81)
2018-05-29 13:23:32,074 DEBUG RFM2Pi 13209 Timestamp : 1527600212.07
2018-05-29 13:23:32,075 DEBUG RFM2Pi 13209 From Node : 8
2018-05-29 13:23:32,076 DEBUG RFM2Pi 13209 Values : [583, 566, 3463, 0, 263.14, 300, 300, 300, 300, 300, 300, 0]
2018-05-29 13:23:32,077 DEBUG RFM2Pi 13209 RSSI : -81
2018-05-29 13:23:32,079 DEBUG RFM2Pi 13209 Sent to channel(start)' : ToEmonCMS
2018-05-29 13:23:32,079 DEBUG RFM2Pi 13209 Sent to channel(end)' : ToEmonCMS
2018-05-29 13:23:32,276 DEBUG MQTT Publishing: emon/emontx3/power1 583
2018-05-29 13:23:32,277 DEBUG MQTT Publishing: emon/emontx3/power2 566
2018-05-29 13:23:32,279 DEBUG MQTT Publishing: emon/emontx3/power3 3463
2018-05-29 13:23:32,280 DEBUG MQTT Publishing: emon/emontx3/power4 0
2018-05-29 13:23:32,282 DEBUG MQTT Publishing: emon/emontx3/vrms 263.14
2018-05-29 13:23:32,284 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-05-29 13:23:32,286 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-05-29 13:23:32,288 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-05-29 13:23:32,290 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-05-29 13:23:32,292 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-05-29 13:23:32,293 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-05-29 13:23:32,295 DEBUG MQTT Publishing: emon/emontx3/pulse 0
2018-05-29 13:23:32,297 DEBUG MQTT Publishing: emon/emontx3/rssi -81
2018-05-29 13:23:32,299 INFO MQTT Publishing: emonhub/rx/8/values 583,566,3463,0,263.14,300,300,300,300,300,300,0,-81
2018-05-29 13:23:42,007 DEBUG RFM2Pi 13210 NEW FRAME : OK 8 69 2 50 2 133 13 0 0 161 102 184 11 184 11 184 11 184 11 184 11 184 11 0 0 0 0 (-81)
2018-05-29 13:23:42,010 DEBUG RFM2Pi 13210 Timestamp : 1527600222.01
2018-05-29 13:23:42,012 DEBUG RFM2Pi 13210 From Node : 8
2018-05-29 13:23:42,013 DEBUG RFM2Pi 13210 Values : [581, 562, 3461, 0, 262.73, 300, 300, 300, 300, 300, 300, 0]
2018-05-29 13:23:42,014 DEBUG RFM2Pi 13210 RSSI : -81
2018-05-29 13:23:42,015 DEBUG RFM2Pi 13210 Sent to channel(start)' : ToEmonCMS
2018-05-29 13:23:42,017 DEBUG RFM2Pi 13210 Sent to channel(end)' : ToEmonCMS
2018-05-29 13:23:42,209 DEBUG MQTT Publishing: emon/emontx3/power1 581
2018-05-29 13:23:42,211 DEBUG MQTT Publishing: emon/emontx3/power2 562
2018-05-29 13:23:42,213 DEBUG MQTT Publishing: emon/emontx3/power3 3461
2018-05-29 13:23:42,216 DEBUG MQTT Publishing: emon/emontx3/power4 0
2018-05-29 13:23:42,218 DEBUG MQTT Publishing: emon/emontx3/vrms 262.73
2018-05-29 13:23:42,221 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-05-29 13:23:42,224 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-05-29 13:23:42,226 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-05-29 13:23:42,228 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-05-29 13:23:42,230 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-05-29 13:23:42,233 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-05-29 13:23:42,235 DEBUG MQTT Publishing: emon/emontx3/pulse 0
2018-05-29 13:23:42,238 DEBUG MQTT Publishing: emon/emontx3/rssi -81
2018-05-29 13:23:42,240 INFO MQTT Publishing: emonhub/rx/8/values 581,562,3461,0,262.73,300,300,300,300,300,300,0,-81
2018-05-29 13:23:45,042 DEBUG emoncmsorg Buffer size: 3
2018-05-29 13:23:45,043 INFO emoncmsorg sending: http://10.1.3.242/html/emoncms/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1527600202.151188,8,581,570,3477,0,262.56,300,300,300,300,300,300,0,-80],[1527600212.070328,8,583,566,3463,0,263.14,300,300,300,300,300,300,0,-81],[1527600222.006624,8,581,562,3461,0,262.73,300,300,300,300,300,300,0,-81]]&sentat=1527600225
2018-05-29 13:23:45,086 DEBUG emoncmsorg acknowledged receipt with 'ok' from http://10.1.3.242/html/emoncms
2018-05-29 13:23:51,852 DEBUG RFM2Pi 13211 NEW FRAME : OK 8 69 2 47 2 142 13 0 0 166 102 184 11 184 11 184 11 184 11 184 11 184 11 0 0 0 0 (-80)
2018-05-29 13:23:51,855 DEBUG RFM2Pi 13211 Timestamp : 1527600231.85
2018-05-29 13:23:51,857 DEBUG RFM2Pi 13211 From Node : 8
2018-05-29 13:23:51,858 DEBUG RFM2Pi 13211 Values : [581, 559, 3470, 0, 262.78000000000003, 300, 300, 300, 300, 300, 300, 0]
2018-05-29 13:23:51,859 DEBUG RFM2Pi 13211 RSSI : -80
2018-05-29 13:23:51,861 DEBUG RFM2Pi 13211 Sent to channel(start)' : ToEmonCMS
2018-05-29 13:23:51,862 DEBUG RFM2Pi 13211 Sent to channel(end)' : ToEmonCMS
2018-05-29 13:23:51,916 DEBUG MQTT Publishing: emon/emontx3/power1 581
2018-05-29 13:23:51,918 DEBUG MQTT Publishing: emon/emontx3/power2 559
2018-05-29 13:23:51,920 DEBUG MQTT Publishing: emon/emontx3/power3 3470
2018-05-29 13:23:51,922 DEBUG MQTT Publishing: emon/emontx3/power4 0
2018-05-29 13:23:51,924 DEBUG MQTT Publishing: emon/emontx3/vrms 262.78
2018-05-29 13:23:51,927 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-05-29 13:23:51,929 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-05-29 13:23:51,931 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-05-29 13:23:51,933 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-05-29 13:23:51,936 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-05-29 13:23:51,938 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-05-29 13:23:51,940 DEBUG MQTT Publishing: emon/emontx3/pulse 0
2018-05-29 13:23:51,942 DEBUG MQTT Publishing: emon/emontx3/rssi -80
2018-05-29 13:23:51,944 INFO MQTT Publishing: emonhub/rx/8/values 581,559,3470,0,262.78,300,300,300,300,300,300,0,-80
2018-05-29 13:24:01,750 DEBUG RFM2Pi 13212 NEW FRAME : OK 8 67 2 47 2 152 13 0 0 190 102 184 11 184 11 184 11 184 11 184 11 184 11 0 0 0 0 (-82)
2018-05-29 13:24:01,753 DEBUG RFM2Pi 13212 Timestamp : 1527600241.75
2018-05-29 13:24:01,754 DEBUG RFM2Pi 13212 From Node : 8
2018-05-29 13:24:01,755 DEBUG RFM2Pi 13212 Values : [579, 559, 3480, 0, 263.02, 300, 300, 300, 300, 300, 300, 0]
2018-05-29 13:24:01,756 DEBUG RFM2Pi 13212 RSSI : -82
2018-05-29 13:24:01,757 DEBUG RFM2Pi 13212 Sent to channel(start)' : ToEmonCMS
2018-05-29 13:24:01,758 DEBUG RFM2Pi 13212 Sent to channel(end)' : ToEmonCMS
2018-05-29 13:24:01,846 DEBUG MQTT Publishing: emon/emontx3/power1 579
2018-05-29 13:24:01,848 DEBUG MQTT Publishing: emon/emontx3/power2 559
