I donât see why not. Itâs got the same processor with the same capabilities. You will need to modify the output format of whichever sketch you use - you can lift that pretty much intact from one of the V3.4 sketches. Youâll also need to check the serial baud rate that the ESP expects, and change your sketch to suit.
You could even run emonLibCM on the V2 if you wished - a lot of the work I did on that was done on a V2 because of the availability of outputs that I could hang a 'scope on to check the timing, etc.
The recent problems surrounding the ESP8266 stem from it sending back unwanted data to the V2. As long as the V2 doesnât look at the serial port and try to act on incoming characters, that wonât be a problem (or you can leave the incoming data connection off).
Many thanks.
I will give it a go. The only slight issue might be sourcing the CT pcb socket as this board was only built to monitor temperature. If they are the same as the sheild I may be able to take an unused one of the sheild I have and use that.
The emonTx V2 was supplied in kit form for assembly by the user, so itâs perfectly feasible to build it with only the temperature sensor input - also using the same 3.5 mm jack. The V2 predates the emonTH by a fair while, so while by no means conclusive evidence, the only way to measure temperature in its day was to have the V2.
The parts list file I quoted is dated February, 2012, The V2.2 schematic is dated 28/8/2013. The earliest emonTH sketch I have is dated November, 2013.
Ianâs been around here for a long time, I think heâs going to be right about what he has.
Same here.
And Iâve no intention of parting with it - having most if not all the I/O easily accessible makes it exceedingly useful. I only wish the radio wasnât soldered down quite so effectively, else I could put a RFM69CW on it. Now that would be very useful too.
I thought of that, and I do have one, but protecting all the other parts is the worry. If Iâd got a huge soldering iron, Iâd fashion a âUâ shaped bit with the correct dimensions to get on all 14 joints at the same time.
Hence the need for a nozzle thatâs (roughly) the same size as the footprint.
If the gun produces sufficient heat, the solder will melt and the module can be removed before
other components are damaged. IIRC, the temp specs of most components are rated at max
heat for 10 seconds. It should be fairly easy to get the board unsoldered in half that time or thereabouts.
Yes, but thatâs the lead temperature, not the body. Thereâs an electrolytic capacitor less than 1 mm away from the module, and I wouldnât fancy its chances even with 5 s of enough temperature to melt solder.
If that cap is a through-hole devce, it could be removed prior to the âsurgery.â
The key is the nozzle, and the distance the nozzle is held from the board, which is quite close.
When I worked at a USN repair depot, we had a hot-air solder/de-solder station for a few months.
(it was a demo, but they wound up not buying it as the price was quite steep) At any rate,
it worked well and didnât fry anything else on the boards we used it on. But, as I mentioned, the
heat it produced enabled the job to be done quickly.
I looked up my old orders. I purchased a number of
EmonTX Low Power Temperature Node kits in 2012. From memory only the parts needed for temperature measurement were supplied. The kit cost ÂŁ18.50 and I got a video of Glyn or Trystan cycling to the post office as proof of posting!
Iâd forgotten the kit, but remember the video. I think it was Trystan. It was downhill, feet off the pedals, all the way. I donât think we got to see the slow grind back up the hill afterwards.
I have checked the emontx and the Huzzah and they both function. @Robert.Wall you mentioned I could use probably use emonLibCM. Is there a sketch you would suggest as the best to start with?
Look at the example sketches that come with emonLibCM. The only real differences between the V3.4 and the V2 is the pin numbers and the radio settings.
Hereâs my âcrib sheetâ giving all the relevant I/O. emonTx IO-all.zip (1.1 KB)
and, for what itâs worth, Iâve found my test sketch: EmonTxV2CM_868.ino (5.9 KB)
That one is by no means a âproductionâ sketch, the âpayloadâ to emonCMS is totally non-standard, it was adapted from the V3.4 sketches simply to prove that the library would work with the V2.
