Can Sync re-create Input processes?
I’m migrating from emoncms.org to my local emon server (running low-write ver. 10.1.10 from the emonSD-17Oct19 image) on a Rasp Pi 3. In the Sync section on my local server, I’ve Sync’d Inputs from my emoncms.org account and then I Syn’c Feeds, one at a time by pressing Download. And now I’m sending the API inputs to my local emon server identical to the ones I’ve been sending to emoncmc.org for years. The only problem is that the Input processes don’t work - the Arg section indicates “Feedid does not exists or has been deleted”. Is there a way to get the Sync process to get the Input processes to recognize the Input stream arriving at the local server? (without having to rebuild them all manually!)
Hello @sroof Feed re-mapping for input processors does not currently work when copying the inputs over from emoncms.org due to differences in the emoncms software versions. I would like to get this working but still some way off.
