What am I dong wrong ??? Somehow I am logging power and not the kWh even though power to kWh shows correct value.
Oh looks like i am too hasty in posting a question. The answer is simple, power to kWh does not change the output. Instead it is “log kWh to a feed” type process element so log to a feed is not needed.
so log to a feed is not needed. so log to feed is included on the process.
