Hello, I am trying to calibrate the voltage input from my emonTX device because here in continental Europe (Italy) we have a different voltage than UK and the readings are not correct.
I have an emonPI device, which I have correctly configured with this config lines:
[nodes]
[[5]]
nodename = emonpi
[[[rx]]]
scales = 0.958,0.958,0.958,0.00958,0.1,0.1,0.1,0.1,0.1,0.1,1
units = W,W,W,V,C,C,C,C,C,C,p
I would like to do the same thing with emonTX, which communicates with emonPI via a wi-fi connection (using the emonESP module).
In the inputs page of the administration panel of the emonPI, I can see the emontx node, but this node is not present in the emonhub.conf file. Can I add it? What node id should I use?
I think that using the emontx3cm15 node id should be an error, since that node is related to the radio link. But I cannot use it, because emonTX is too distant from emonPI and the radio link doesn’t work very well.
So, which is the correct way to recalibrate emonTX+emonESP readings?
