Calculations in Virtual Feeds failing
Noted thanks. I can see the same issue, fix appears a little more complex than I first thought so it may be a little while until this is fixed on emoncms.org.
Thank you @TrystanLea . Will you notify this thread once the update has been made?
Can an issue be created on GitHub?
