Calculating Underfloor Heating Output for 200mm pipe spacing
I thought I would give heatloss.js a go and try putting in all the data for my house.
I quickly discovered that it only supports 150mm pipe spacing for underfloor heating, so thought I would have a look to see what is required to add support for other pipe spacing distances.
(that fact that my house has 200mm pipe spacing is a bit of a sore point - I didn’t realise the importance of the pipe spacing before I started leaning about heat pumps)
The result is this little Python project:
I don’t know if it is of use to anyone else, but I am hoping to use the findings to improve heatloss.js.
Hi Nicholas, a good idea. I checked it against the CIBSE guide “ The underfloor heating design & installation guide” and information is a good fit. For example the CIBSE guide indicates flow temp of 37.5C with a room temp of 20C and a heat output of 67W/m2 for R=0.05 with a pitch of 100mm (16mm pipe). The MCS derived curve you shared indicates an “eyeball” fit of ~63 W/m2 for a Tf-Tr=17.5C.
The most interesting fact from your curves was the observation that the flow temperature must be ~5C higher than the room temperature to have “effective” heat flow in to the room. The CIBSE guide simply has a MWT cut off at 30C for room temperature ranges from 15C to 24C. Always nice to see the tabulated data as curves.
Thanks for the info.
Frank
Thanks for doing the cross reference.
If you put it through the algorithm, you get:
>>> watts_m2 = ufh_heat_output(
...     pipe_spacing=100,
...     r_value=0.05,
...     flow_temp=37.5,
...     room_temp=20
>>> print(watts_m2)
62.05763537499999
I have no idea how significant 67W/m² vs 62W/m² is.
Given that there are errors absolutely everywhere, presumably that is close enough!
Hi Nicholas, I made a mistake reading the CIBSE table. I will try and correct it later. CIBSE states a heat output of 70.3 W/m2 ( and not the 67 W/m2 I stated previously) for 100mm pitch with MWT of 35C (deltaT=5C). So the difference would now be ~8W/m2. I think it is probably close enough in typical mixed radiator and underfloor heating designs with all the other variables involved. However, it shows a larger difference with low temperature UFH designs running with a MWT of 30C, which seems equivalent of jumping a pitch size or more.
For example, the difference between a 150mm and 200mm pitch is 4.9 W/m2 for a MWT of 30C, 11.6 W/m2 for a MWT of 35C or 19.4 W/m2 for a MWT of 45C.
I have probably confused you with my reply, but I hope it helps.
Frank
