Hi, I’m new here and have everything setup and working, I’m using Emoncms with Home Assistant and I am looking for a way to calculate cost in a feed or via a ‘Post Process’, if this possible?
I have searched and not found a definite answer.
Also I’m still confused as to whether I should be using Real Power or Apparent Power, I sort of understand the difference between the two but confused how to calculate the overall cost of electricity throughout the day.
Any help will be appreciated
Thank you
