I have a local host setup. I want my button in emoncms to operate an led via arduino (which is connected to raspberry pi) on which emoncms is running. Any help please.
Hello @Usman36264
The emoncms dashboard buttons update the emoncms feed that its associated with. You could create a script that reads the value of this feed and updates the arduino.
Here’s an example of the feed value API:
http://localhost/emoncms/feed/value.json?id=10
You could load this into a python script with:
import requests, json
emoncms_apikey = "apikey"
emoncms_server = "http://localhost/emoncms"
reply = requests.get(emoncms_server+"/feed/value.json", params={'id':10,'apikey':emoncms_apikey})
value = reply.text
print(value)
If instead of using the arduino you can connect the LED straight to the RaspberryPi it’s probably a lot simpler, here’s an example using gpiozero:
import requests, json, gpiozero
led1 = gpiozero.LED(9)
value = int(reply.text)
if value>0:
led1.on()
else:
led1.off()
