Please can you help me with a Bill of Materials - inverter unit in garage with PV on roof (separate building ~10 meters) and not near main consumer unit. I will need a Type 2 setup. Many thanks Neil
Hello Neil, welcome to the community
Can you explain a little more what you would like to measure and what result you’d like ?
Start maybe to elaborate a little about your setup. Depending on what system you have several solutions can be proposed. You have 1 phase, 2 or more phase system ? voltage ? region ?
What would you like to measure ? Production only ? usage ? …
As with many open source systems, many things are possible but first you need to know what you really want to do.
thanks all sorted, i have a spare AC/AC plug and CT Clamp but its ok
