Beyond Weather compensation ( Daikin )
Yes, it’s called Modulation and provided the heat pump is sized correctly, it’d work just fine. But that’s the problem. They aren’t and Daikin decided Madoka shouldn’t shut off over the setpoint (relying on Modulation instead - which I get btw).
What they could do is if MMI sees that it can’t modulate lower than the flow temp will go, realise this and shut off when the indoor temp goes over the setpoint, but only if the flow temp can’t be lowered. How hard would that be to code in? Not at all. Will they do it? No.
Has anyone else also thought the blue LED on the modoka effects the internal temps ?
Looks like the answer is a firm Yes: HELP - Daikin Configuration WD curve and modulation with a Madoka room thermostat - #24 by squarepeg77
Yes. It’s a flawed piece of hardware in so many ways.
