yorks
(Martin Woods)
1
Hello everyone,
I’ve been following these forums for a while, and they seem to be the best place to ask this question. Could I get some opinions on Baxi ASHPs, please?
We’ve been planning to install a heat pump for over a year as part of a major renovation of a very old house. Recently, we were informed that we need a slightly larger ASHP than originally planned because we’re struggling to achieve the insulation levels in the old parts of the house.
Initially, we planned to go with a Vaillant aroTHERM plus 7kW, but it turns out we need a Vaillant aroTHERM plus 12kW. Unfortunately, planning wouldn’t accept it as a non-material amendment and is trying to force a full planning application with noise testing, which isn’t an option due to the cost and time involved. I’m aware the government has just launched a review of these restrictive laws, which will see the physical size of the units relaxed, but we can’t wait that long as we need heating.
An installer suggested going with the Baxi-HP40-50, which is under 0.6m3. However, I don’t know much about Baxi heat pumps, only that their gas boilers seem okay.
From what I’ve read, they are twice as noisy (68dB vs 60dB) as the equivalent Vaillant. I also noticed that you don’t see any Baxi heat pumps on the league tables.
Has anyone had any experience with these? The other option is to stick with gas for a bit longer and wait until the UK reforms the planning laws. In the meantime, we’ll upgrade the heating and water systems so they are ASHP ready.
Thank you, Martin
Hi Martin, and welcome to the forum.
I’ve not seen anyone with a Baxi, as it’s not one of the brands favoured by any installers.
What kind of house do you have? I’m guessing solid walls if it’s very old. You could look at Heatpump + Fabric for Pre-1900 Houses to see if there’s one similar to yours, and see what kind of heatpump and performance they have been getting.
It’s very common for installers to massively over-estimate the size of a heat pump required; often it’s the air change rate that gets set too high in calculations. I would suggest finding a local Heat Geek to do a proper heat loss assessment of your property.
Changes to planning rules are being made “early next year” as announced by the government this week:
- Remove the 1m boundary rule, enabling heat pumps to be installed within 1m of the property boundary.
- Increase the size limit of the heat pump for dwellinghouses from 0.6m3 to 1.5m3.
- Double the number of heat pumps permitted, from one to two for detached dwelling houses.
- Support the rollout of air-to-air heat pumps that can also provide a cooling function.
yorks
(Martin Woods)
3
Hi Tim
Thanks for the reply I’ll take a look at that.
Yes I had noticed there isn’t much information on Baxi HPs.
I’ve done my own heat calcs, as they were ~5% off a recommended professionals. I’m was pretty confident of mine, but it was nice to have validation.
I had read this yesterday, it can’t come soon enough, however I need to be installing January, and having no heating isn’t an option.
I think I might just wait it out for a few years.
Many thanks
I’m sure there are other large units that could fit within current planning restrictions. For example, Mitsubishi Ecodan 11.2 kW and NIBE 2040 12kW units are only 0.51m³, and I think you might be able to squeeze in a Daikin Altherma or a Samsung Gen 7.
Edit: A Grant Aerona³ 13kW would also fit.
yorks
(Martin Woods)
5
I’ll check those out thank you. But Baxi isnt popular, that’s good to know. Its certainly loud twice that of the Vaillant at 68dB VS 60bB
I looked up the datasheets for Baxi HP40-50 and they look to be running on R32 which is decent but superseded by R290. Performance looks comparable to the Mitsubishi, though somewhat louder.
yorks
(Martin Woods)
7
Thank you, I hadn’t realised it was quite an old model.
Yes the noise is a major concern as it would only be a few meters from a bed room.
Originally I had planned to go with Vaillant, but as stated the unit volume is the problem.
Is there a popular manufacturer of ASHP with a 12kw model that’s under this silly 0.6m3 that you are aware of please? Certainly something equally quiet with a refrigerant that’s better for the environment?
Such a shame they haven’t already make this change, I’m tempted to just pop one in without planning, but it seems too risky
The manufacturers I mentioned above are all reasonable ones with 11-13 kW units, though I don’t know which run on R290.
While R32 does have higher GWP, it’s only a problem if it leaks, which it shouldn’t. Performance is broadly similar.
It might be worth getting a door blower test to measure the actual air change rate, for a more accurate heat loss.
toadhall
(Alun Hawkins)
9
That sounds pretty close, even for one of the quieter units. Have you gone through the MCS020 noise assessment paper exercise? That should tell you if it is a non-starter. Unfortunately, the planning application route is something of a lottery, with some authorities using the MCS assessment, while others insist on a full report and use lower noise limits. Google is your friend to find out more.
As an aside, my Samsung Gen 6 12kW is inside the 0.6m3 limit, but is R32. Not sure if the Gen 7 (which is R290) is inside the current limit, but would probably be OK with the proposed revised limit.
yorks
(Martin Woods)
10
The bedroom in question is a spare that we don’t use as one so it doesn’t matter to us and it’s facing a wall. There are no neighboring bedrooms in view.
I have done the MSC020 myself yes using their template. It just passes with the Vaillant which are quieter at 60.
Thank you ill check Samsung out, and do a bit more research. It feels like this would be much easier with a change to the law, it’s just unfortunate we can’t wait.
yorks
(Martin Woods)
11
A door blower test sounds interesting, so we could just do this after we’ve done all the insulating, but before committing on the heat source. I’ll do some research on this, I wonder how it works along side a MVHR system.
