I have MySolar setup and working with my PV system which has a battery, however I decided with very little solar now I should take advantage of my Octopus Go tariff and charge the battery as well as my EV. The inverter is setup to charge between 00:30 and 04:30 but nothing is shown, I assume due to the negative solar feed offsetting the grid pull? I see the solar feed coming in from 04:30 onward, which will be the battery discharging.
I’ve never done any configuring of the the emoncms panels so don’t want to destroy anything until someone points me the right way! Ideally, I would want to see the true grid feed level and a negative solar to be battery charging.
Thanks for any assistance!
