I think I now have (see conf below), & I restarted emonHub.conf on both PiZ #1 & #2b; had to pop out for an hour, and now both are getting through to the main emonPi’s Inputs page
I will update my crib sheet & start again with PiZ #3
Earlier today I did run (via ssh to PiZ #2) miniterm /dev/ttyAMA0 115200 and miniterm --rtscts /dev/ttyAMA0 115200 but that didn’t seem to help; part of the problem is that I don’t know what miniterm is / does, so will go away and read up about it …
Comparing all the version numbers in the emonCMS Admin section of both Pi Zeros, and all seem to be exactly the same
I half hoped that by hashing out the RFM2PI section within the emonTX’s emonHub conf meant that the issue of RF would go away (& it did with PiZ #1), but will re-read your comments and revert.
For clarity, herewith my emonHub conf from the emonTx / PiZ #1. It is the same was for PiZ #2 except for the nodename.
####################### emonhub.conf #########################
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
####################### emonHub settings #######################
[hub]
loglevel = DEBUG
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
#[[RFM2Pi]]
# Type = EmonHubJeeInterfacer
# [[[init_settings]]]
# com_port = /dev/ttyAMA0
# com_baud = 38400 # 9600 for old RFM12Pi
# [[[runtimesettings]]]
# pubchannels = ToEmonCMS,
# subchannels = ToRFM12,
# group = 210
# frequency = 433
# baseid = 5 # emonPi / emonBase nodeID
# calibration = 230V # (UK/EU: 230V, US: 110V)
# quiet = true # Disable quite mode (default enabled) to enable RF packet #debugging, show packets which fail crc
# # interval = 300 # Interval to transmit time to emonGLCD (seconds)
[[SerialTx]]
Type = EmonHubTx3eInterfacer
[[[init_settings]]]
com_port= /dev/ttyAMA0
com_baud = 115200
nodeoffset = 0
nodename = Serial_PiZero_hotwater
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 192.168.2.50
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
subchannels = ToEmonCMS,
timestamped = True
node_JSON_enable = 1
node_JSON_basetopic = emon/
# Type = EmonHubMqttInterfacer
# mqtt_host = 192.168.2.50
# mqtt_port = 1883
# mqtt_user = emonpi
# mqtt_passwd = emonpimqtt2016
# pubchannels = ToRFM12,
# subchannels = ToEmonCMS,
# # emonhub/rx/10/values format
# # Use with emoncms Nodes module
# node_format_enable = 1
# node_format_basetopic = emonhub/
# # emon/emontx/power1 format - use with Emoncms MQTT input
# # http://github.com/emoncms/emoncms/blob/master/docs/RaspberryPi/MQTT.md
# nodevar_format_enable = 1
# nodevar_format_basetopic = emon/
[[emoncmsorg]]
[[[init_settings]]]
url = https://emoncms.org
senddata = 1 # Enable sending data to Emoncms.org
sendstatus = 1 # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
sendinterval= 30 # Bulk send interval to Emoncms.org in seconds
####################### Nodes #######################
[nodes]
## See config user guide: https://github.com/openenergymonitor/emonhub/blob/emon-pi/conf/emonhub.conf
[[5]]
nodename = emonpi
[[[rx]]]
units = W,W,W,V,C,C,C,C,C,C,p
[[6]]
nodename = emontxshield
[[[rx]]]
names = power1, power2, power3, power4, vrms
datacode = h
scales = 1,1,1,1,0.01
units = W,W,W,W,V
[[7]]
nodename = emontx4
[[[rx]]]
units = W,W,W,W,V,C,C,C,C,C,C,p
[[8]]
nodename = emontx3
[[[rx]]]
[[9]]
nodename = emontx2
[[[rx]]]
[[10]]
nodename = emontx1
[[[rx]]]
scales = 1,1,1,1,0.01,0.01,0.01,0.01,0.01,0.01,0.01,1
[[11]]
nodename = 3phase
[[[rx]]]
names = powerL1, powerL2, powerL3, power4, Vrms, temp1, temp2, temp3, temp4, temp5, temp6, pulse
[[12]]
nodename = 3phase2
[[[rx]]]
[[13]]
nodename = 3phase3
[[[rx]]]
[[14]]
nodename = 3phase4
[[[rx]]]
[[15]]
nodename = emontx3cm15
[[[rx]]]
names = MSG, Vrms, P1, P2, P3, P4, E1, E2, E3, E4, T1, T2, T3, pulse
datacodes = L,h,h,h,h,h,l,l,l,l,h,h,h,L
scales = 1,0.01,1,1,1,1,1,1,1,1,0.01,0.01,0.01,1
units = n,V,W,W,W,W,Wh,Wh,Wh,Wh,C,C,C,p
whitening = 1
[[16]]
nodename = emontx3cm16
[[[rx]]]
whitening = 1
[[19]]
nodename = emonth1
[[[rx]]]
names = temperature, external temperature, humidity, battery
datacode = h
scales = 0.1,0.1,0.1,0.1
units = C,C,%,V
[[20]]
nodename = emonth2
[[[rx]]]
datacode = h
units = C,C,%,V
[[21]]
nodename = emonth3
[[[rx]]]
datacode = h
units = C,C,%,V
[[22]]
nodename = emonth4
[[[rx]]]
datacode = h
units = C,C,%,V
[[23]]
nodename = emonth5
[[[rx]]]
names = temperature, external temperature, humidity, battery, pulsecount
datacodes = h,h,h,h,L
scales = 0.1,0.1,0.1,0.1,1
units = C,C,%,V,p
[[24]]
nodename = emonth6
[[[rx]]]
units = C,C,%,V,p
[[25]]
nodename = emonth7
[[[rx]]]
units = C,C,%,V,p
[[26]]
nodename = emonth8
[[[rx]]]
units = C,C,%,V,p
