Is it possible to automate the “run process” in emoncms/postprocess ? If so, how, please?
I’ve got everything setup and working on my dashboard, but I had to use post process to get reliable kWh figures, so would like it to run daily by itself…
Hello @phproxy, there isn’t a way to automate this at present from within the postprocess module. Is there a reason that you cant use the power_to_kwh input process?
Hello. Has there been any development on automating the post process? I tried running the script in the readme file but it does not process the two feeds I have.
I am currently running one processes on two inputs. Both are running powertokwh. Just recently, I started using the Power to kWh on the input feed. However, I have a lot of history currently in the database that I used the post process to convert to kWh and would like to continue using that data in my graphs until such time as the input conversion can show me a month or so of historical data. At that point, I can stop using the post-process. I would like to automate the post process so I do not have to continually access the website and push the buttons.
I never did find a resolution to this issue. What I am finding is my data gets corrupted every couple of months and I have delete all the data and redownload. So the Post Process for the backup data wasn’t necessary any longer.
