experts,
arotherm plus, brand new install, getting following challenges (arotherm plus, 97/6 , HEX 150, underloor heating plus DHW cylinder)
- which circuit diagram is best to suit HEX and hydraulic station with underfloor heating 1 zone, 1 DHW ?
- how to change target floor temperature? whatever i do is always 0
- how to force DHW and heating to run in parallel? whatever i do with 720 , runs only one at a time. (great engineering, never again german made)
- how to fix F.1100 ? if system is designed to run 75degree max, how 95degree possible to blew up fuse for cut off? who did come up from engineering department with that wonderful idea? none could install 50cent fuse instead of expensive cut off thermostat replacement.
appreciate help
