Yes arduino and raspi are in the same network. I have tried and I can ping from raspi to arduino with no problems.
This is the sketch:
//simple sketch reading from DHT22 and posting up to emoncms.org using the ESP8266 wifi module.
// This file is part of OpenEnergyMonitor project.
#include <ESP8266WiFi.h>
#include "DHT.h"
#define DHTPIN 12
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
DHT dht(DHTPIN, DHTTYPE);
const char* ssid = "XXXXXXX";
const char* password = "XXXXXX";
const char* host = "192.168.1.xxx/emoncms";
void setup() {
Serial.begin(9600);//Baud rate
delay(10);
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
dht.begin();
int value = 0;
void loop() {
delay(2000);
++value;
// DHT22_ERROR_t errorCode;
Serial.print("Requesting data...");
// errorCode = DHT.readData();
// switch(errorCode)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println("Failed to read from DHT sensor!");
return;
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print("\n");
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\n");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C\n ");
// We now create a URI for the request
String url = "/input/post.json?csv="+String(h)+","+String(t)+"&apikey=XXXXXXXXXXXXXXXXX"; //Enter api key here
Serial.print("Requesting URL: ");
Serial.println(url);
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil('\r');
Serial.print(line);
Serial.println();
Serial.println("closing connection");
